Seventy-two throttle stuck open
Old Sep 12, 2012 | 03:57 PM
XKnight's Avatar
XKnight
No issues with my 72. Did you swap out the grips or do anything to the throttle? Also, what's your riding experience?
Old May 30, 2013 | 03:27 PM
Ironrodent's Avatar
Ironrodent
My 12 iron did that today....awaiting anyone to post in my new thread. I just pulled in clutch and hit the kill switch.
Old May 30, 2013 | 03:33 PM
Kontankerous's Avatar
Kontankerous
Hmmm...seems a lot of new models having odd issues. Throttle sticking, bolts snapping...
you guys be careful out there!
Old May 30, 2013 | 07:43 PM
elfnyc's Avatar
elfnyc
throttle cable pinched or tooooo tight while you were turning bars ? dont know
glad your ok though
Old May 30, 2013 | 07:52 PM
HedleyLamarr's Avatar
HedleyLamarr
took mine in for the 5K service a few weeks ago and the guy said mine was sticking open, but he wouldn't do anything about it since I had put on aftermarket grips...jerkoff
oh well, I don't really keep it wide open too often anyway
regardless though, that's kinda gay that he wouldn't do anything about it
Old Mar 12, 2016 | 04:59 PM
OCDbikr's Avatar
OCDbikr
Originally Posted by kckid
The throttle tension screw wasn't tight. I had the bike towed to HD service shop and asked them to checkout the throttle.
I'm certainly not ruling out that I may have revved it a little, but I'm thinking stuck throttle because I let up off the throttle, pulled the clutch in and the engine continued to rev really high. Anyway, it happened so fast I didn't get to hit the kill switch.
No word yet from service shop about the throttle>
The bike could have not revved AT ALL, but if you kept the exact same throttle twist and didn't slack off at all (but squeezed the clutch in all the way) it would have sounded "wound out". Think about it... When you squeeze the clutch, you HAVE to let off the throttle. In a "knee jerk" emergency reaction, it's easy to forget a step in normal operations, or even add a step or two. But make no mistake, if you kept the throttle the same, and squeezed in the clutch as a reaction to something out of the ordinary, it will wind out loudly and still be functioning perfectly normal, with no malfunction at all.
Old Mar 12, 2016 | 07:08 PM
hpotter's Avatar
hpotter
Just another thinking,..it may be no relation to the throttle but just have high idle....? High idle is the common issue seen on EFI engine sportster .
Just realize this is 3 years old post... OMG.
Old Sep 7, 2024 | 05:39 PM
Nicodemus2021's Avatar
Nicodemus2021
New Member
I'm certainly not ruling out that I may have revved it a little, but I'm thinking stuck throttle because I let up off the throttle, pulled the clutch in and the engine coninued to rev really high. Anyway, it happened so fast I didn't get to hit the kill switch.
so what did the HD shop say about your throttle?
Old Sep 8, 2024 | 05:33 PM
John Harper's Avatar
John Harper
They said you revived a Zombie post, from 2012. Kckid's kid probably owns the bike by now.
John
Old Sep 8, 2024 | 06:55 PM
Rob Roy's Revenge's Avatar
Rob Roy's Revenge
Welcome to the Forums from the UK.
As John Harper said, this is a twelve year old "Zombie" thread, if you are having trouble with your throttle sticking, you could start your own new thread.
