19 inch wheel in place of 21 inch wheel???
Old 09-11-2012, 11:33 AM
dobeman21's Avatar
dobeman21
dobeman21 is offline
Default 19 inch wheel in place of 21 inch wheel???
I just bought some chrome rims off ebay and one of them was a 19 inch rim and I should have gotten a 21 inch rim (have a 13 sportster). Will putting the 19 inch rim on with a new tire affect anything? Thanks in advance for any help.
Old 09-11-2012, 11:44 AM
cHarley's Avatar
cHarley
cHarley is offline
Yes, the bikes handling in the corners and on the twisties will be much better with the fatter 19" 100mm tire, and you'll likely get 3x more mileage from the fatter tire than the skinny 21".
I changed mine to the 19" several years ago and would never go back.
Old 09-11-2012, 11:50 AM
Maidenas's Avatar
Maidenas
Maidenas is offline
I guess you have a 72, right? Well you get better handling, but somehow ruin the 70s chopper look (if you have a 72)
Old 09-11-2012, 12:48 PM
dobeman21's Avatar
dobeman21
Thanks for the responses, and yes it is a 72- I had to order a tire from my local dealer so will be putting it on once it gets in- will just leave the front spoke wheel on for the time being.
Old 09-11-2012, 01:46 PM
Thorshammer's Avatar
Thorshammer
Thorshammer is offline
I've a 21' for sale in the florida crew classfies.
Old 09-11-2012, 01:51 PM
TW's Avatar
TW
TW is offline
How's that front fender gonna look when you put a shorter wheel under it? You might want to think about that. Also, your fender mounting brackets may rub the sides of the fatter 19" tire.
Old 09-11-2012, 02:11 PM
cHarley's Avatar
cHarley
cHarley is offline
Unless the 72's fender is narrower than a standard Sporty fender, it won't rub and the overall diameter of the wheel and mounted tire is less than 1/4" difference. The 19" tire has a taller sidewall.
Old 09-11-2012, 02:17 PM
AlexWS's Avatar
AlexWS
AlexWS is offline
Yea, unless the fender is different this won't be an issue. Switched my 04 custom to a 19, no problems/
Old 09-11-2012, 02:53 PM
dobeman21's Avatar
dobeman21
Need a white wall
Old 09-11-2012, 02:55 PM
dobeman21's Avatar
dobeman21
harley's website says the 19 inch thunderstar wheel fits my 2013 seventy two, so rubbing shouldn't be a problem I wouldn't think.
Quick Reply: 19 inch wheel in place of 21 inch wheel???
