The manuals give you a dry step by step procedure but sometimes you don't see the process and sometimes it can seem confusing. A video gives visual clues you cant get from a book.
YouTube made it easy to understand dis-assembly of front forks, the book was a bit confusing.
Am I missing something...what's the difference between the "Sportster Edition DVD for $42.95 and the "Sportster Maintenance How-To DVD Bundle" for $49.99?
It's been so long since I ordered mine, I don't remember. But the $42.95 DVD is all you need, along with the Service Manual of course.
Edit: Just went and looked again and here the list of the extra "bonus" bundle items. So, if you think you need them, go for it.
2000 – 2003 Front & Rear Brake Caliper Service
1999 – Older Single Piston Front & Rear Brake Caliper Service
Inside the Primary Case & Primary Chain Tight Spot
I have the online membership to FMH, and the service manual. That said, I've also noticed J&P Cycles posts a lot of the same useful "How To's" on YouTube for free. Other free YouTube demos are pretty useful too. FMH should take down their "electrical explanations" section immediately and try to forget it ever happened.
That said, IMHO FMH is very useful and helpful in its own right. Like anything else, there are alternatives and room for improvement. I'm just not convinced its worth the money quite yet, especially when I can get most of what I need from the manual and YouTube.
You're correct, there are now A LOT of YouTube videos available for free and if you have the time to search through the thousands of videos available it's certainly cheaper. Of course, not all of these homemade YouTube videos are technically correct or complete, so you need to have the technical ability to differentiate the good ones from the bad.
The FMH video is targeted directly at new DIY wrenchers, and gives them all the basics for doing a standard service in one video, rather than hunting through hundreds or thousands on on-line YouTube clips.
Given the hundreds/thousands of dollars people will spend on chrome and bling without thinking twice, $43.00 is pretty reasonable, IMO and even though I don't really need it any longer, I found it a big asset when I first started wrenching on my Sporty. If only the guy on the video would loose the NJ accent.....
