Installed HIDs
Old Sep 20, 2012 | 09:43 PM
Davemac122383's Avatar
Davemac122383
Originally Posted by AwesomeIndeed
I can't speak for the other guy, but my '12 Iron stock headlight bulb was downright terrible and not only did it not give off very much light at all no matter how I aimed it, the light was yellow yellow yellow and not a white light. Took it out the first time at night and was surprised I made it back home to be honest. They definitely do NOT throw a lot of light, even with Silverstar Ultras or ZXE's, as I have tried both before going with an HID like I use in all of my vehicles.
The whole HID legality thing has been beaten to death. Is it technically legal? No. HID bulb technology has come a LONG way in the last few years, though. Your chances of blinding oncoming traffic unless you're using a simple reflector housing with no bulb shield is slim to none when aimed properly. You don't get the full desired even flood pattern of the HID or the "correct" cut off, but the stock bulb shield and reflector housing is designed to cut off the beam no matter what and it does in fact do this, even with HID bulbs. Telling people that they're just blinding oncoming traffic is just not correct information if the headlamp is aimed properly. Yes you are throwing more light in more places, no you should not be blinding people unless you have it aimed at them.
Using a non-halogen based bulb in our scoots is a day and night difference in not only overall brightness but the reach of the light as well. There are people that do things incorrectly all over the place, but there are also a small group of us with extensive first-hand experience with the subject and know how to achieve the desired result safely and effectively.
Agreed.
Old Sep 21, 2012 | 09:42 AM
tripn88's Avatar
tripn88
You need to retrofit a projector into your housing to get all the use out of that HID. Also make sure the bar and shield on front of housing is right side up.
Old Sep 21, 2012 | 10:33 AM
Zenmervolt's Avatar
Zenmervolt
No. It hasn't. Not in any way that is relevant to the discussion of reflector optics. The problem is NOT a technological problem. It CANNOT be solved, or even mitigated, with "technological advancements." The size, shape and positioning of the HID light source (the arc) are all fundamentally different from those of a traditional Halogen filament bulb and no amount of "technology" can change that. You will NOT get a legal beam pattern from a HID in a filament housing, and it will NOT help you see better. Just because something seems "brighter" does not mean that you're actually seeing more.
Saying that "new technology" in HID bulbs makes the retrofits into H4 housings OK is like saying that "new technology" in the production of diesel fuel makes it OK to run diesel in a gas engine.
http://www.danielsternlighting.com/t...nversions.html
Some relevant quotes:
Now, what about those "retrofit" jobs in which the beam cutoff still appears sharp? Don't be fooled; it's an error to judge a beam pattern solely by its cutoff. In many lamps, especially the projector types, the cutoff will remain the same regardless of what light source is behind it. Halogen bulb, HID capsule, cigarette lighter, firefly, hold it up to the sun—whatever. That's because of the way a projector lamp works. The cutoff is simply the projected image of a piece of metal running side-to-side behind the lens. Where the optics come in is in distributing the light under the cutoff. And, as with all other automotive lamps (and, in fact, all optical instruments), the optics are calculated based not just on where the light source is within the lamp (focal length) but also the specific photometric characteristics of the light source...which parts of it are brighter, which parts of it are darker, where the boundaries of the light source are, whether the boundaries are sharp or fuzzy, the shape of the light source, and so forth.
The most dangerous part of the attempt to "retrofit" Xenon headlamps is that sometimes you get a deceptive and illusory "improvement" in the performance of the headlamp. The performance of the headlamp is perceived to be "better" because of the much higher level of foreground lighting (on the road immediately in front of the car). However, the beam patterns produced by this kind of "conversion" virtually always give less distance light, and often an alarming lack of light where there's meant to be a relative maximum in light intensity. The result is the illusion that you can see better than you actually can, and that's not safe.
It's tricky to judge headlamp beam performance without a lot of knowledge, a lot of training and a lot of special equipment, because subjective perceptions are very misleading. Having a lot of strong light in the foreground, that is on the road close to the car and out to the sides, is very comforting and reliably produces a strong impression of "good headlights". The problem is that not only is foreground lighting of decidedly secondary importance when travelling much above 30 mph, but having a very strong pool of light close to the car causes your pupils to close down, worsening your distance vision...all the while giving you this false sense of security. This is to say nothing of the massive amounts of glare to other road users and backdazzle to you, the driver, that results from these "retrofits"
The ONLY way to "safely and effectively" install a HID system is to replace the entire housing with one designed for a HID bulb from the get-go. It will NEVER be possible to "safely and effectively" drop a HID bulb into a housing designed for a halogen filament bulb. Anyone who thinks otherwise has absolutely zero grasp of optical science.
Old Sep 21, 2012 | 10:36 AM
Davemac122383
That would be the best bet for a great custom look and the best light pattern and output. It may be something I could do down the road, a friend of mine retro-fits projectors in car headlights. I am pretty happy with the light now with the HIDs, I may look into getting a better aftermarket housing/reflector but not really sure that is need now, just something I can think about.
Old Sep 21, 2012 | 11:26 AM
aklim156581's Avatar
aklim156581
Originally Posted by Davemac122383
I just installed a cheap chinese special HID ballast and bulbs that was much needed for my bike. I couldnt see **** with the factory bulb or even a silverstar bulb. I bought the ballast off ebay for ~$10 shipped and 2 6000k bulbs for ~$12. Even if the bulbs go once a year its still pretty cheap. I think in the spring I'll look for a different headlight assembly, with better reflectors inside. Anyone recommend a headlight assembly that works well with HIDs? I'd love to get a HD LED Headlight but the price is kinda steep.
The ballast I bought was a micro/mini, only about 2 1/2" long and wide so it fit nicely inside the headlight. I didnt want to mount the ballast under the tank and run and extension.
I used the cheaper stuff on my Ford Excursion and MB. Changed it several times over a couple of years till I decided to buy the good stuff on my Vette and never had an issue so I changed all the cars over to the pricier stuff WITH GOOD REFERENCES. Good stuff doesn't go for cheap nor does it have to. Sure, I could get a few months up to a year with the cheap stuff but what is my time worth? Especially in a month when I have to do shoulder and elbow surgery and will not be able to wrench on it for 4 plus months.
Old Sep 21, 2012 | 12:40 PM
AwesomeIndeed's Avatar
AwesomeIndeed
I know that article says that it's never going to be out of date, but in some aspects it is (I did read the entire thing). There is a lot of useful information in it, that I'll agree with. Most of it is true.
The only way to "legally" (safely and effectively is not a blanket statement, there are limiting factors but it is possible) install an HID system is to replace everything, yes. Some retrofit manufacturers do offer products with proper bulb shielding and capping, to help some of the issues with beam pattern and cutoff, and in some cases they do play very nicely with reflector housings. Also, the quality of the bulb and ballasts in question can and do decide if a sloppy or clean pattern and cutoff can be achieved using a reflector. I know he doesn't seem to think so and it's not 100% optically correct or legal for that matter, but I have been working directly with HID systems for the past 10 years or so on many different vehicles and I can say that yes it can be done (on most recent vehicles) and in an acceptable fashion in regards to usable light in the correct location, vision obstruction to oncoming traffic and so forth. There are a TON of crap products out there and it's very easy to think that all of them are alike, but there are a few good retrofit manufacturers out there that are taking steps to work around the conceptual flaws and do have good products.
The question of legality isn't being side-skirted here. It's not legal to install HID retrofit bulbs into non-HID housings. This is something everyone who does a retrofit should consider. Also, if you're not capable of performing proper before and after testing and adjustment of usable light and the placement and reach of said light on your vehicle, you probably shouldn't attempt to put HIDs in your vehicle.
I'm going to stand behind my statement that you can achieve an acceptable result using quality products without a projector beam headlamp assembly. It's not going to be optically correct on all fronts like a factory job would be, but it is going to produce more usable light which will allow you to see more of the road not just immediately in front of you, but signage and objects in the distance as well as to the left and right of the bike. Whether or not you blind or produce glare for oncoming drivers or yourself is going to be based on the quality of the product used and your knowledge and ability to adjust it until it's acceptable for both sides.
I'm not disagreeing with your statements, but plainly lumping it all into the same category and just calling it all crap is not correct. I know the laws of optical science can't be bent or broken or rewritten, but there can be a happy medium between the does and does not work scenario.
Old Sep 21, 2012 | 01:41 PM
Zenmervolt's Avatar
Zenmervolt
I never said you needed a projector assembly.
I said you needed an assembly that was designed for a HID bulb from the outset. There were/are several reflector assemblies that were designed from the ground up for HID bulbs (the '95 Lincoln Mark VIII LSC and certain models of Subaru come to mind).
What I have said, and what is not really arguable, is that you cannot get a proper beam pattern by putting bulb type X into an assembly designed for bulb type Y. In the same way that you can't just re-base an H7 bulb to shove it into an H4 housing and get an acceptable beam pattern, you also cannot just re-base a D1R, D2R, D3R, or D4R and shove it into an H4 housing to get an acceptable result. And you definitely cannot use a D1S, D2S, D3S, or D4S (the "S" signifying that these bulbs are designed only for projector housings while the "R" bulbs are designed for HID-only reflector housings).
The reflector and the bulb type are a matched pair. Using a bulb in a reflector that was not designed for it is never advisable.
Old Sep 21, 2012 | 07:34 PM
AwesomeIndeed
I'm agreeing with what you're saying here (and have experience with cars like the Mark VIII, several Subaru models including the earlier WRX STi, Toyota Prius, Shelby GT500 Mustang, etc). Proper and acceptable are two different terms. Proper being 100% and acceptable being somewhere between 1% and 99%, dependent on a few factors.
I will not argue that you can get a proper beam pattern, but I will say that you can get one that works and lets you see more without distracting other traffic around you. No placebo, but an honestly brighter AND more usable and further reaching beam of light than the crap Harley puts in these bikes stock.
H4 bulbs are actually some of the easiest ones to work with in terms of HID retrofits when you buy the good ones. The shields on the bulbs are some of the better designs in terms of keeping light from reaching places it's not supposed to go.
It's not legal or even optimal, but it works and works well for an inexpensive upgrade solution to the excuse for a headlamp HDs come stock with.
Old Sep 22, 2012 | 08:02 AM
1200Cdriver's Avatar
1200Cdriver
I am always baffled by these discussions when people say the Sporty has a lousy stock headlight. Here in rural Westmoreland County Va. street lights are few and far between. There are miles and miles of unlit highway with 10 foot tall corn on both sides. My headlight is more than adequate allowing me to see both shoulders of the road and pick out deer's eyes long before there is danger. At 70 years old I don't think I have any kind of super vision. Just wondering.
Old Sep 22, 2012 | 09:44 AM
AwesomeIndeed
I guess you're one of the lucky ones. With a properly adjusted headlamp, my stock bulb barely lit up a 6-7ft wide area and it was all concentrated in one very dim spot on the road. Making more adjustments only moved the tiny concentrated spot around. Probably a defective bulb, but I was going to change to HID anyway so I knew it would be better than that.
My father's RK's stock headlamp is about 20 times as effective (and was a much whiter light) as my stock one was. No issues seeing anything with his.
