recommend tire pressure?
Old Sep 20, 2012 | 02:05 PM
cHarley's Avatar
cHarley
The following chart lists several popular tires used on Sportsters and the tire manufacturers recommended inflation pressures when installed on a Sporty.
I've run all of the below on my Sporty except for the new Michelin Commander II's. I'm currently running the Dunlop E3's.
Old Sep 20, 2012 | 02:20 PM
Knights2TheEnd's Avatar
Knights2TheEnd
Thanks man, so I guess it is 30, which I found to be too low and sucks for handling
Old Sep 20, 2012 | 03:13 PM
cHarley's Avatar
cHarley
If you notice, the 401 tire has a much higher max pressure rating (41 psi). There shouldn't be any problem running it a couple of pounds higher than the 30 psi recommended in the OM. I think Harley recommends the stock tires a bit on the soft side for the sake of a better (softer) ride, rather than for best handling.
Old Sep 20, 2012 | 09:15 PM
Devils Cut's Avatar
Devils Cut
I run 40 P.S.I. on front & rear tires. My last tires where when I'd bought the bike new and just replaced. They 13,700 on them running 40 psi. I'll run 40;psi with these new I have now!!!!
Old Sep 20, 2012 | 09:21 PM
BaldHOG1222's Avatar
BaldHOG1222
Run mine at @ 35psi each (stock dunlops with tubes). Tires glide a little better, and the bike corners a little better(I feel like I get just a tad bit more lean angle)
Old Sep 20, 2012 | 09:29 PM
XKnight's Avatar
XKnight
I always add a few PSI to whatever the owners manual recommends. It's always better to have a little more air in the tires than less and the pressure always goes down.
JimGnitecki
Jul 24, 2021 01:18 PM
sn95bullitt
Wheels/Tires
Dec 2, 2015 07:23 AM
jmoore1777
Jul 20, 2012 06:52 AM
mxz600
Apr 14, 2009 08:26 PM
principalman
Jul 1, 2007 02:19 PM
