2010 Sportster 48 PROBLEM!!
Old Sep 21, 2012 | 12:50 AM
cameron.woolery's Avatar
cameron.woolery
Stage II
Default 2010 Sportster 48 PROBLEM!!
I took my bike out today without incident. About an hour later I went to take it out again and turned the key and got full electrical. However, the normal sound of the fuel injector filling did not happen, and I was unable to start the bike. I did not get an error code on the tac.
I checked all of the battery connections and they appear to be tight.
I am definitely a rookie with bikes.
Any advise please?
Old Sep 21, 2012 | 01:01 AM
SD1's Avatar
SD1
fuel pump. it may be on a fuse. but that is the noise you hear when you turn your key to the on position. Was it turning over but not starting?
Old Sep 21, 2012 | 04:35 AM
chevy94ss's Avatar
chevy94ss
Since you said you are a rookie w bikes, easy things first. Is it in neutral? Run switch set to on? Not meaning to sound rude but its easy to overlook the simple stuff
Old Sep 21, 2012 | 11:49 AM
cameron.woolery
Stage II
SD1: I have the ignition on fully, but the bike does nothing after that. I get the usual indication lights on the tac, but it seems like the fuel injector isn't priming. So it turns on but will not turn over. Do you know where the fuse is for the fuel injector?
Chevy:Youre not being rude, I am a rookie as far as mechanical issues go, this is my first major issue. I went back and did all of the initial steps to ensure it wasn't me. However, the problem still remains. The only thing I can see and I stated above is that the fuel injector is not getting power.
Old Sep 21, 2012 | 12:12 PM
Afrobaron's Avatar
Afrobaron
Check the switch on the handle bars (right one) and make sure it is not set to off. I have hit mine accidentally getting off one day and it freaked me out when I went back later.
Old Sep 21, 2012 | 12:15 PM
02Deuces's Avatar
02Deuces
done the same thing...was freaked out for about 45 secs.....Then ohh duh...
Old Sep 21, 2012 | 01:21 PM
SD1's Avatar
SD1
Its next to the battery. Its not well protected, chance the fuse got blown or possibly corrosion and a short. I would look there first.
Crash Davis
Oct 17, 2024 06:50 PM
-Wade-
Sep 9, 2016 07:16 PM
kwwn15
Jan 30, 2016 09:25 PM
krtp1
Jul 14, 2014 10:23 PM
B_CONA
Mar 5, 2014 07:36 AM
