Use the coupon code HD It is $99 and free shipping and it supports one of our sponsors. I have it and it works great. ft/lbs, in/lbs, and n/m
1/2" drive? Most of my sockets are either 3/8" or 1/4". I guess one can use a 1/2"-to-3/8" converter like I do with my 3/8"-to-1/4". I have both an ft/lbs and in/lbs torque wrenches already though.
Reading this thread title, I'm sorry but I had to shake my head. No offense but if you have to ask how important torque specs are, you maybe shouldn't be wrenching on your bike.
^^maybe not but I enjoy challenging things, a.k.a things i dont know how to do...and called my father in law he has a torque wrench for ft/lbs and in/lbs. Ty guys ill post pics next week..
I've seen the results of tests done in Hot Rod, Motor Trend and other mags and 20% to 50% off is the average accuracy of the wrist. Being dead on accurate is not nearly as important as uniformity. I watched a genius in rural W.Va. replace a head gasket on an Olds F-85 with the 215 cubic inch Turbo V8. I offered to bring him a torque wrench the next but he said he knew what tight was. The next day he went down the road and less than 5 minutes he was back with water vapor, water and combustion gasses blowing out around the left front wheel. I never forgot that.
Again to answer OPs question there is a reason critical parts have torque spex. However, most torque wrenches you have access to will NOT do the job correctly.
Even brand new, out of the box, they need to calibrated before you use them. Then on a regular basis or after a drop, they need to be re-calibrated. Most folks do not know that, thus they think they are torquing to spec, but in reality are doing nothing but twisting a wrench.
Reason: Trains and cell phones do not mix when typing paragraphs
I have 6 torque wrenches and have never torn anything up using them but I have busted a few things not using them. If they were as inaccurate as you claim then everybody would posting about something they broke using them. So far no one has.
Say what you want, I used to calibrate them. I have first hand how off the are. After calibration, the start loosing their edge with each use; hence the need to continually recalibrate.
I challenge you to find a local calibration lab and have your six trusty wrenches tested. You'd be surprised at how off they.
You are most likey torquing everything uniformly but to a higher or lower spec.
Oh, and I have read threads on here where folks were stripping threads while going to the designated torque spec.
Following torque specs and procedures doesnt insure the right preload when your torque wrench is off. Even brand new out-of-the-box torque wrenches have been tested at 10-20% off. The solution is to have it calibrated. Causal wrenchers should have this done annually and even more frequently if they are using the tool on a daily basis or assembling engine compo- nents. There are some gadgets available online that claim to convert a standard ratchet into a torque wrench by digitally displaying the amount of torque being applied. As long as that unit is as consistent as advertised, it could be used at home as a checker. ARP techs offer torque wrench calibration at every race they attend. If thats not in your schedule, they recommend contacting the wrenchs manufacture for service. There are also companies like Team Torque (TeamTorque.com) that change $30 to test and calibrate just about any torque wrench.
