Electrical problem no power
Old Aug 21, 2019 | 02:21 AM
sechracer's Avatar
sechracer
NVM, did not see it was a resurrected thread or that the fix was found or why it showed up as a new posted thing when I was in touring not sportsters..... wtf....
Old Jan 27, 2020 | 10:52 PM
Tiger Ray's Avatar
Tiger Ray
Stage I
Originally Posted by seehogs
Look at the ground cable where it touches the plastic shield in the battery box.
If there are signs of heat melting the plastic your problems are most likely
a bad ground wire or loose connections.
This happened on 2004 XL that I was working on.( bad wire with original battery only
14,000 miles) Everything checked out fine until a load was put to it then, poof no lights and no start.
whats a load min.
Old Jan 28, 2020 | 04:11 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Is that a question and where are you seeing load min?
Old Feb 23, 2020 | 06:48 PM
Poncho_Bob's Avatar
Poncho_Bob
Stage IV
Hi, new guy here with the same problem on '04 sporty 883 without security system: Battery, cables, fuses good. Turn key switch to accessory and I get the lights on the speedo cluster. Turn key to on and it all goes away. After searching and reading the forum, I tested the key switch and it reads continuity. Still no workie. Thinking the contacts might be dirty in the unservicable key switch and won't hold a load, I replaced it. Still no workie.
I was hoping to find a simple answer without having to take the bike apart and going through the wiring harness completely.
Old Feb 24, 2020 | 08:59 AM
JimmyL's Avatar
JimmyL
I had the same problem. Lights come on, battery fine, hit the start button and everything goes dark. The cables looked fine. It turned out to be the positive cable though. It was corroded under the insulation where it couldn't be seen near the starter. It just about fell apart when I took it off. New cable, all good now.
Old Feb 24, 2020 | 09:12 AM
Poncho_Bob's Avatar
Poncho_Bob
Stage IV
At least you got to push the start button before it went dark. I am in the dark as soon as the key goes to the on position.
Old Feb 24, 2020 | 12:17 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
How did you determine the battery and cables were good?
Old Feb 24, 2020 | 05:10 PM
Poncho_Bob's Avatar
Poncho_Bob
Stage IV
By removing the battery and the cables and starting a '69 Pontiac with them.
Old Feb 24, 2020 | 09:34 PM
Dan89FLSTC's Avatar
Dan89FLSTC
You need a wiring diagram, and a voltmeter, to troubleshoot the issue.
Old Feb 24, 2020 | 09:50 PM
Poncho_Bob's Avatar
Poncho_Bob
Stage IV
Apparently, you aren't aware of a common failure with these bikes either. I have the wiring diagram and the multi meter I stole from the Navy I will start taking the bike apart and tracing wires as a last resort..
