I will check the fuel shut off this evening, if I can. How do I remove it without spilling all the gas out of the tank? Pinch the hose from the petcock before it gets to the shut off?
Also, I will reattached the battery connections.
You have to drain the tank first before you can remove the petcock to clean the screen.
Well, things have gone from bad to worse. I have new spark plugs, and I put new spark plug wires on, and now it stalls, stutters, and takes a while to fire up. Idle is poor and rough, after warm up. I have the manual and looked at removing the petcock, but I don't really want to futz with it. I am going to have it shipped to a shop and looked at by a professional. I don't want a project bike. Frustrating.
As has been previously mentioned, pull the petcock, clean the filter screen that's inside the gas tank, inspect the vacuum-diaphragm in the petcock, and the vacuum line from the petcock to the manifold.
One OTHER thing that might be happening is that the trigger-wires to your coil may be loose - stock, they are a "pinch-cap" connection that can vibrate open after a while.
Project bike? C'mon - Man Up- figuring this out is well within your capabilities, especially if you've got the factory manual to use as a guide. If you DON'T have the factory manual - that should be the very next money you spend on the bike, and the FIRST money you spend on any others that you acquire, no matter the brand.
Turns out the carb was all gunked up. Now I know what the looks and sounds like. Thanks for the thoughts guys, I appreciate it. Rode in to work today and it's a beauty again.
Well, seems like my praise was pre-mature. Same thing happening, only worse. I'm trying to work through the final 2gallons in the tank so I can clean out the petcock and replace all the fuel lines. Oddly, after the bike stalled completely, and being unable to start it with the starter, I was able to pop the clutch and it fired right back up. Any idea what that means? Sounds electrical.
Do you get this popping type of sound when it happens? if so, it might be your vacuum piston jumping around. The symptoms you are desrcibing are very similar to mine when my vacuum piston was jumping around due to the needle moving up and down. I would ride and out of nowhere the bike would make like a suction popping sound and it would jerk as if all the fuel just stop flowing, then in less than a fraction of a second the bike would go to normal. It would happen constantly
