Neg. Jumper Cable-Convenient Ground Point
Old Nov 25, 2012 | 05:39 PM
anjz's Avatar
anjz
Stage III
Default Neg. Jumper Cable-Convenient Ground Point
Hi All,
I am hoping someone might be able to tell me a convenient grounding point to attach a negative jumper cable to a 2013 Iron 883. I can't attach it to the lug on the engine where the battery ground cable terminates (b/c I can't reach it without enlisting the help of a 2 year old with tiny hands) and I can't attach it to the negative battery terminal with the battery installed.
I am looking for a location where the metal jumper cables won't scratch the bike, so I don't want to attach it directly to my frame.
Any help will be greatly appreciated.
Andy
Old Nov 25, 2012 | 05:51 PM
baka1969's Avatar
baka1969
You could attach it to either the feeler for the foot peg or the shift lever.
Old Nov 25, 2012 | 06:12 PM
anjz's Avatar
anjz
Stage III
That's great news Baka1969! Thanks so much!
Old Nov 25, 2012 | 06:14 PM
HarleyScuba's Avatar
HarleyScuba
Rear brake disc.
Old Nov 25, 2012 | 06:16 PM
Von_Zipper's Avatar
Von_Zipper
Oh no! I would not let that current flow thru ball bearings.
Old Nov 25, 2012 | 08:06 PM
HarleyScuba
I thought about that. I can't imagine they'd get any hotter than the friction caused while spinning. Current goes through the swingarm, too. I could be wrong. My other concern was scoring the rotor, but I've done it a half dozen times or so with no appearent ill effect. If you have a feeler or shift lever you can clamp to, by all means, do that. If your clamps are shaped in a particular manner, you might get a hold of the grounding lug behind the primary, next to the starter.
Old Nov 25, 2012 | 09:09 PM
anjz's Avatar
anjz
Stage III
Thanks for all of this information.
Scotty7one7
May 2, 2017 01:35 AM
Magiclint
Jul 5, 2016 09:35 AM
fenwick
Mar 8, 2015 02:35 PM
LarryLives
Sep 30, 2011 07:06 AM
kjelders
Apr 26, 2011 08:30 AM
