Won't turn over!!!
Old Jan 10, 2013 | 01:38 AM
DOMAPOI's Avatar
DOMAPOI
Big problems occur when the connections/screws come loose, start arcing (like when starting, and deposit carbon on the battery terminal and the contacts of the wires hooked up to the battery. That causes an insulator effect and have to be filed or ground off to make good contact again. Corrosion is another problem but have not really heard about a problem with that too much with gel cell batteries like most motorcycle batteries are.
Old Jan 13, 2013 | 01:49 PM
kong123's Avatar
kong123
6th Gear
All 15 amp fuses in box are o.k. positive battery cable burnt in two locations and broken wires.Im sure this is not the problem but replacing it.Checking out the 12v 30 amp in box to see if its any good.
Old Jan 13, 2013 | 02:04 PM
kong123's Avatar
kong123
6th Gear
Is there a fuse under gas tank or anywhere else.Besides the 15 and 30 amp fuses by the battery? Thanks Ron
Old Jan 13, 2013 | 03:22 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
All the fuses are in the battery area.
Old Jan 13, 2013 | 03:34 PM
kong123's Avatar
kong123
6th Gear
Thank you!
Old Jan 13, 2013 | 04:51 PM
Brion B's Avatar
Brion B
Let us know what the problem turns out to be.
Old Jan 13, 2013 | 09:41 PM
Roni's Avatar
Roni
I would bet money that it is a loose neg term connection either at the battery or at the other end of the cable on the engine block.
Old Jan 19, 2013 | 12:48 PM
kong123's Avatar
kong123
6th Gear
I should be able to get back to the bike,after two cars broke down!!!!Bought a new battery cable two places was burnt through and a new 12v30amp thats in the panel that holds the fuses.If its not any of these maybe i'll put in a new ignition.
Old Jan 19, 2013 | 12:49 PM
kong123's Avatar
kong123
6th Gear
Roni, i will check that first!!!
Thanks everyone for the help!!!
Old Feb 2, 2013 | 10:41 AM
kong123's Avatar
kong123
6th Gear
I believe the ignition switch is bad also!
Can anyone help me on the switch? Do you have to remove Tankk bolt?
Easy job?
Thanks Ron
