hi idle 883c
Old Jan 22, 2013 | 08:30 PM
meanderingvanner's Avatar
meanderingvanner
6th Gear
Default hi idle 883c
heres what i have. 09 883c (elect fuel inject) that has a hi idle and has code p0118 ("ET Sensor Voltage Open/High EFI"). originally my bike spun a woodruff key on the crank, so replaced oil pump, pinion gear, oil drive gear ,new lifter, and installed n4 andrews cams, as all the factory stuff was all tore up. timing was set correct. check clearances etc. reassembled everything, and now the bike idles very hi. also replaced intake gaskets. just about fed up and ready to take bike to shop and have them fix it, and tell me it was something simple. any help would be appericated
Old Jan 23, 2013 | 07:09 AM
mrfikser's Avatar
mrfikser
check the plug on the engine temperature sensor, it my just be loose/unpluged...if not just replace it..costs like $35-$40...they go bad sometimes ..
Jackpoticorn
Aug 12, 2017 09:55 AM
epictetus13
Jun 3, 2014 08:55 AM
Finnking
Nov 21, 2012 11:08 AM
array
Jun 20, 2008 06:11 AM
tgaetto
Apr 15, 2007 04:00 PM
