riser the same on superlow and custom
Old Jan 30, 2013 | 08:16 PM
riiano's Avatar
riiano
Default riser the same on superlow and custom
noticed that the 1200 custom has the speedo mounting down behind the bars, was wondering if could mount on 2012 superlow with out major changes
Old Jan 30, 2013 | 09:48 PM
JeffJA's Avatar
JeffJA
You want to mount the custom riser on the low? Yes, it should be a pretty easy swap, you may need to also swap the speedo wire harness to depending on what Indicator lights are on the low, i have the complete custom riser/speedo mount with the harness if you're looking for one.
Old Jan 30, 2013 | 10:50 PM
c0jones's Avatar
c0jones
I don't think it's that easy. The SuperLow doesn't have removable risers. You would need to have the lower handlebar clamp milled off, then drill the upper tree. Or replace upper tree with part from 2011 & newer 1200C. An upper mid glide tree from Vulcan Engineering might work too.
Old Jan 30, 2013 | 10:55 PM
JeffJA's Avatar
JeffJA
Oh, i thought just the "48" had that kind of tripple tree?
Old Feb 4, 2013 | 04:37 PM
c0jones's Avatar
c0jones
I looked at the dealer Saturday. The SuperLow's lower clamp cannot be milled off. There's not enough material. It might be possible with a 48, they're beefier.
r0880
Nov 30, 2019 08:42 PM
sickskinz
Dec 17, 2012 08:22 PM
Wetfeet
Dec 6, 2012 02:54 PM
Twisted Noodle
Jan 19, 2010 12:04 AM
DrPlastic
Jan 10, 2008 04:41 AM
