Brake Fluid Question
Old Feb 3, 2013 | 08:39 AM
Geoff's Avatar
Geoff
Default Brake Fluid Question
I bought my '02 Sportster 1200 last October. I've been using the winter months to do maintenance on the bike.
Yesterday I checked the brake fluid in each master cylinder. The bike is supposed to use Dot 5, according to the cap on the master cylinder. To my knowledge, Dot 5 is purple in color. However, the brake fluid in my bike has a light amber color like Dot 3 and 4.
The front and rear brakes work great. I simply want to top off the fluid in each master cylinder. Is it safe to assume my brake fluid is Dot 3 or 4?
Old Feb 3, 2013 | 08:43 AM
mrfikser's Avatar
mrfikser
from what i have heard DOT5 turns amber with time...so I would say normal...
Old Feb 3, 2013 | 08:44 AM
Scuba10jdl's Avatar
Scuba10jdl
Yep. As it ages it will turn yellow/clear. Change it with fresh stuff every 2 years, and you shouldn't have any problems.
Old Feb 3, 2013 | 08:52 AM
Jackie Paper's Avatar
Jackie Paper
Changed out my Dot 5 couple years ago to fresh fluid and it was back to amber color in a year. Go by the label or manual. Note.. my fluid was original to bike but other then amber, looked good. Dot 5 kicks butt compared to 3 or 4..especially on a bike with the hand cylinder above tank. Sad that due to the ABS Harley need to switch all back to the Dot 4 and decided it was best for all (that part was a good idea)
Old Feb 3, 2013 | 02:47 PM
Geoff's Avatar
Geoff
Thanks to all for the input. I decided to change the fluid in both cylinders and replace with Dot 5.
drspencer
Dec 21, 2011 11:07 AM
Mr Mojo Risin
Jul 16, 2011 09:33 PM
Taterdog
Mar 29, 2010 06:00 AM
Fiddler
Jul 7, 2008 06:17 AM
anubisss
Mar 6, 2008 11:42 PM
