clutch cable broke
Old Feb 10, 2013 | 01:52 PM
mcarb80682's Avatar
mcarb80682
Stage III
Default clutch cable broke
I need help my clutch cable broke and I replace it but while putting in the new clutch cable I over tighten and it broke off. The screw is stuck on the cover. What are the suggestion of what i should do
Old Feb 10, 2013 | 02:10 PM
rquest's Avatar
rquest
Not exactly sure which screw you're talking about. The adjusting screw that goes into the side engine case? If so can you get an easy-out into it or is the cable still intact? You may have to take that case off.
Old Feb 10, 2013 | 02:22 PM
mrmikey32's Avatar
mrmikey32
go get the tool called a grab it from home depot.
**** works wonders!
Old Feb 10, 2013 | 04:24 PM
mcarb80682's Avatar
mcarb80682
Stage III
The bolt that broke is the clutch that connects to the motor . The clutch cable is connected to the motor still
Old Feb 10, 2013 | 04:27 PM
mcarb80682's Avatar
mcarb80682
Stage III
. I would need to cut the cable and untreat the clutch cable the clutch cable is hollow and grab it is for a bolt
Old Feb 10, 2013 | 07:14 PM
73oldsman's Avatar
73oldsman
You're going to have to pull the cover back off the tranny and go ahead and cut the cable. You will have to get another cable. Now, with the tranny cover in front of you, maybe you can back out the hollow threaded piece of the nut with an easy out. Good luck.
keith t
Jun 29, 2016 10:43 AM
Northern Glide
Mar 3, 2013 12:17 PM
rodney123456
Sep 30, 2012 09:43 AM
barnzee
Jul 4, 2011 11:40 AM
jgcable
Oct 22, 2007 01:19 PM
