Glad you're ok.
A few years back I was taking a corner and hit some wet leaves on the ground and it threw me sideways pretty good. I pulled out of it but just about crapped my pants haha.
Wet leaves and corners or brakes don't mix! Fact I don't like them at all! lol
OP, could have hit a reflector button or painted stripe right when you were goosing it. Glad you're ok!
Yep. Last winter, freezing temps, hit the road to go to my work, the highway being salted as usual, so no worries. I was riding at 75 MPH.
And then, on that bridge, with some side winds, a 15 yards (at least) long icy patch. The rear went sideways, I held on tight, countersteering as needed.
Did something like that pulling out of a gas station. Must have gotten oil or gas on the back tire. Pulled out turning right,...hit the throttle and back ends starts to go sideways, ready to fall over. Without thinking I let off the gas and it came back up. Heart pounding like crazy.......
I had the same sort of thing on my roadking the other day...but it was the front wheel hit something slippier when I was changing lanes and the front end slid sideways for a some 10 feet or so...scared me so tight I just about bit a hole in the seat...
I actually like that feeling "most" times when I'm throttling it.....I don't like it when I have a tire going down. I actually came sliding sideways full throttle out of the convenient store parking lot onto my main road a week or so ago just for the hell & it had been a while since I actually got to go for a ride.
Similar feeling I had on a Honda ST1100 (no ABS) while halfway through an IBA Great Lakes 100 ride a few years ago. In Canada, at night, two lanes, pitch black, good lights and a VERY BIG moose standing in the middle of the road just over a rise. Saw him just in time, braked HARD front and rear the right way but the back end slid out to the left. Kept it fairly straight and stopped 20' in front of the moose. He walked away slowly and I kept on riding.
Probably the only thing that kept me from hitting the Moose was riding within the braking distance of my lights. My next bike, BMW R1100RT, had ABS and I learned how valuable that can be when the unexpected happens. And no matter how good you are, the unexpected WILL happen.
Current ride is a '98 Road King Classic (no ABS). I've slid the back end out on purpose a few times to learn how hard I can break and still keep adequate traction/control. Going to new Metzeler 888 tires next month which will help slightly as new rubber generally does.
Black ice, wet leaves, tar strips...not to mention moose, deer and other hazards. As I get started riding this Spring (if the freaking snow ever stops in NE Ohio...) I will do my usual bike handling practice skill set in a big empty parking lot.
Edit : saw this here as I bought a Sportster for my wife this year, so I'm just learning about Sportster's....
ride safe.
I had a front tire blow out on my old Triumph around 70mph. I got to the side of the road after some handlebar wrangling and smoked a pack of cowboy killers before I could call for a truck.
Could be bad wheel bearings. When I had bad rear wheel bearings, the back end would feel like it shifted a little and would slip slightly when leaning. Was a little unsettling when cornering. The locking would have only gotten worse if I didn't have the bearings changed right away.
Tar snake, maybe? HATE those friggin things. Tar snakes are where they patch the road with tar, and it gets soft in the hot sun. It'll change conditions just enough to make the bike squirrel around a bit. Going around a turn and hitting a tar snake makes one pucker. Could have been oil as well.
