I have the stock rear bullet style lights from my iron and i re located them back farther and want to re wire from the lights to the plug. My problem is the three small connectors inside the bullets I'm not sure where i can find them. Can anyone help me out?
you could lengthen the stock wires. but i have had some luck finding stock connecters on ebay... that or i just order new connectors (non factory) and re-wire all together
My local electrical store has them. So maybe radio shack in the states? or you might be able to look up "wire quick disconnect" or something of that nature and find some online somewhere
I've never seen connections inside the bullets, a photo would sure help. What year bike.
What im referring tois the small metal tabs that the bulb sit on to make connection and light up. The ones at the end of each wire. If i cant find them i figured i can always cut the wires and solder new ones on
Yea you can't get those. Napa auto z sells replacement sockets but nothing like what you have. Been there.
Cut solder shrink wrap.
You know I don't think I have ever seen those anywhere and I go to radio s a lot. Do not even know what they are called.
Socket wire ends, socket connectors your guess;-)
