dynamic ringz
Old Mar 24, 2013 | 09:34 AM
penmoe23's Avatar
penmoe23
Default dynamic ringz
I have seen several people put these on their bikes. Was wondering what parts from their site you bought to get where it has the white running and then turns to amber for the turn signal. Did you use the cluster set up? Also did you have to buy a load equalizer. I just want to do my front signals like this 2012 iron.
Old Mar 24, 2013 | 09:46 AM
elfnyc's Avatar
elfnyc
for my iron 2012 i got the dynamic rings bullet style cluster
they do say u need a resistor/ load equilizer/
but i did not install led to the rear lights - i just did the front
i did not need the load equilizer -
as long as u dont touch the rear lights your fine........and wont have to buy the load eq
this is the exact thing u want to look for
H-D Dynamic Ringz™ Bullet Style Turn Signal LED Inserts
(NON DOT Approved)
Amber/White 1157
A Load Equalizer may be needed
Item: GEN200-AW-1157
http://www.customdynamics.com/harley...gnal_retro.htm
first one on the list just read to make sure it says dynamic ring bullet style
amber / white
Old Mar 24, 2013 | 09:48 AM
elfnyc's Avatar
elfnyc
ps i would also buy smoked or clear lens u cant use the stock yellow lens
http://www.customdynamics.com/harley...rn_Signal_Lens
Turn Signals-New Bullet Style
then look for clear or smoked i didnt like the clear the smoked looks better but thats me
Old Mar 24, 2013 | 09:51 AM
penmoe23's Avatar
penmoe23
Awesome thanks for the help, so without adding the equalizer they must be easy to install just plugin and done correct
Old Mar 24, 2013 | 10:53 AM
elfnyc's Avatar
elfnyc
yeah real easy - pop off lens cover remove old bulb
add some grease to new bulb
use flat head screwdriver to insert and turn the new rings
be sure to tuck the wires that come off the rings behind it so they dont pinch
and get in the way ...
put in place and slap on the new lens covers , done
u may get a fast blink rate when u first turn them on
but turn the key off then back on and try again
mine did not blink fast at all
Old Mar 24, 2013 | 10:56 AM
elfnyc's Avatar
elfnyc
my video - just to show ya how easy lol its nothing great , but the video took longer to edit then to put these lights in lol
Old Mar 24, 2013 | 11:01 AM
penmoe23's Avatar
penmoe23
looks good thanks for the help. definitely will be ordering these with smoke lenses.
RoVo
Apr 21, 2017 09:25 AM
rdrFXDB
Feb 20, 2017 03:54 PM
MattBMiller
Touring Parts
11
Sep 9, 2013 07:55 AM
Cheeze
Jun 19, 2011 07:29 PM
