48 with acceleration problems
Old Apr 18, 2013 | 11:11 AM
TeXbones's Avatar
TeXbones
6th Gear
Default 48 with acceleration problems
My buddy has a 2010 48 that idles fine, but when he accelerates from a stop, the bike will hesitate almost like it wants to cut off, but then takes off like a rocket. There is a recall on that model and it's fuel cap. Has anyone else had this issue and what is the fix.
Old Apr 18, 2013 | 11:21 AM
Jester 08 Nightster's Avatar
Jester 08 Nightster
Ever put some Seafoam through it? Cheap and can't hurt.
Old Apr 18, 2013 | 11:27 AM
jojoenglish85's Avatar
jojoenglish85
I would pull the injectors clean and soak them in sea foam or gasoline over night, and then replace them and see if it works. If it doesn't then i would replace the fuel line and get new injectors spark plugs and wires. Replace them all at the same time as to avoid having to find another issue down the line. Usually things like to mess up in sequence to other problems.
But it sounds like his injectors may be clogged up and its not giving even spray. But try what waht Jester said and run some seafoam before you starting taking parts off.
Old Apr 18, 2013 | 11:57 AM
groverhd's Avatar
groverhd
Seafoam.....i put that **** on everything!
Old Apr 19, 2013 | 04:38 PM
TeXbones's Avatar
TeXbones
6th Gear
Sea foam worked like charm! Thanks to all!
Old Apr 19, 2013 | 05:00 PM
Brion B's Avatar
Brion B
Seafoam is a very good product.Glad to hear it was an easy fix.
svarnster
Jul 26, 2016 05:18 PM
kmc
Nov 26, 2014 08:18 AM
steelerdude1
Jun 1, 2014 08:33 PM
BurpleHugger
May 24, 2010 10:37 AM
skullcrusher
Nov 18, 2009 06:26 PM
