Help please!
Old May 28, 2013 | 07:52 AM
Tmac1382's Avatar
Tmac1382
4th Gear
So just a little update.
Put stock a/c back on. Checked fuelpak settings and went for a ride. Still acted up. Took off fuel pak another test. Issue still present. Checked the plugs. Little worn so I replaced them. Another test. Still doing it. The wife and I went for a ride I just had to short shift it and deal until I got gas. My last idea was bad fuel. Well, long story short my issue was fuel related. I put in 4.1xx gallons. Mind you it's a custom with the big tank. Iirc the tank holds 4.2 gallons. Can we see where this is headed? Yeah, I'm an idiot. Runs great now that it actually has some go-go juice. Now to put my parts back on.
Thank you for all the replys and help.
That is all.
Old May 28, 2013 | 07:59 AM
Iceman24's Avatar
Iceman24
Late to the party, but reading through your posts I was going to reply with (1) exhaust leak or (2) bad fuel....looks like you found the gremlin.
Once you put all the after-market parts back on, let us know if things still function normal...thks!
Another recommendation is to add some fuel stabilizer to the mix - even during summer riding. I always add 1oz. Seafoam per gal with every fill b/c you never know if the pump's good/bad/iffy...JMO.
Old May 28, 2013 | 08:41 AM
rickss69's Avatar
rickss69
So it was running out of fuel...does the low fuel indicator not work in the speedo?
Old May 28, 2013 | 09:02 AM
Tmac1382's Avatar
Tmac1382
4th Gear
It does but its the new combo tach speedo and it seems as if the light comes on a lot later than the stock unit. And with the new parts and lower fuel economy it just kinda snuck up me I guess.
Old Jun 10, 2013 | 01:04 PM
djohng1101's Avatar
djohng1101
I just posted something on this. I finally got hold of V&H and they to.d me to change mode 23 to 50. Trying it this afternoon...
powerman1972
Aug 20, 2014 01:21 PM
tafdeluxe
Mar 22, 2014 08:55 PM
Gregory Agee
Oct 19, 2012 09:41 PM
remmag
Jul 27, 2008 07:35 PM
Big Twi$t
Mar 19, 2008 03:22 PM
