1k mile service
Old May 22, 2013 | 07:16 AM
ProspectNY's Avatar
ProspectNY
Default 1k mile service
OK, so I'm coming up on the 1K mark and I'm curious. The stealership wants to charge like $350 for the service and when I called, they said they pretty much change the oil, oil filter, and primary oil. They also "go over the bike and tighten everything". I have a 2013 Iron and I am pretty handy when it comes to things mechanical, but this is my first motorcycle. Question is, should I just get all the oils and filter and do it myself? Or, just let them do it.
If you say do it yourself, should I get a Harley engine filter and oil and primary oil or use something else? (Yes I know, this is a huge topic of debate, just need opinions) Also, they said they adjust the clutch. I have read up on how to adjust it, just not sure 100% on how to do it. I did go online and get the maintenance manual and it seems pretty easy.
Just want to know what you think I should do. Basically, is it worth it to have it done, or save probably $200 and do it myself. Thanks!
Old May 22, 2013 | 07:18 AM
Ben221's Avatar
Ben221
You will save more than that....I had mine done at a non HD dealer for $220 and I thought I got ripped off.
Do it yourself of find a local shop that does HD work.
Old May 22, 2013 | 07:24 AM
omaho5's Avatar
omaho5
$350.00 is a pretty steep price. That said, there are a few things that need to be looked after/ adjusted. The 1K maint. is an important one.
Old May 22, 2013 | 08:48 AM
HotIceHD's Avatar
HotIceHD
It is very easy. I used K&N oil filter (I use K&N in all my bikes), M1 20W50 for engine, an HD Formula+ for primary.
Yes, you need to do the clutch, and check the chain adjustment.
You also want to check that everything is properly tight. In my case, the exhaust header bolts were a little on the lose side.
I'd invest in the service manual, but there are enough posts around that you can easily do without it, if you do not want to buy it.
Old May 22, 2013 | 10:04 AM
ProspectNY's Avatar
ProspectNY
I was thinking of going this route, but if I'm going to have someone do it, I really would rather HD do it than anyone else. Don't know why though considering they're the biggest rip off.
That's what I struggle with myself. Maybe there are a few things that need to be checked/changed that I don't know about.
I would probably buy the HD filter and primary fluid, but was thinking of using M1 or another popular synthetic oil.
I did check up on the clutch adjustment, and it seems pretty easy. Take cover off, take hex but off with spring, adjust the nuts on the cable, turn until tension, back 1/4 turn, then tighten everything up. In just afraid I'll botch this and need a new clutch.
And why I posted this is because I am battling with either having HD do it, or myself. Grrr!! Thanks for the replies fellas.
Old May 22, 2013 | 11:34 AM
subguy's Avatar
subguy
Harley Service Manual = $60.00. That $60 will save your $$hundreds$$ over time. Easy to follow and you will wonder why anyone pays anyone to service their bikes. Invest in some tools too.
I look at it this way, no one, again no one, cares about your bike as much as you do and you will always do the best job you can.
Plus, you will learn about your bike (and motorcycles). Too many pluses all for $60 which you more than make back by doing your own service.
Old May 22, 2013 | 12:59 PM
MrPeepers's Avatar
MrPeepers
  1. Do it yourself, it's hard to screw up.
  2. Buy the service manual - $60 from HD
  3. I used a K&N filter with the nut welded to the top. This filter, that you can use an ordinary wrench on, will save you the hassle of those oil filter wrenches ans straps. Comes in chrome and black.
  4. I used Mobile 1 V-Twin 20w-50 oil in the engine and primary
  5. Buy yourself some torque wrenches. You probably need two - one won't cover all the ranges you need.
  6. YouTube has plenty of videos on how to do basic maint on a sportster.
  7. The HD service manual has torque specs for all major fasterners.
Forget the dealership - take this opportunity to learn somethign about your bike.
Old May 22, 2013 | 02:26 PM
DallasSportster's Avatar
DallasSportster
I'm all for servicing my own bike, but the 1000 mile service is an important one. I always had the mindset that if I got the 1K done at the dealer, they would not be able to hassle me as much in the event of an issue during warranty. Just my $.02
Old May 22, 2013 | 02:34 PM
orangehotrod's Avatar
orangehotrod
I can't really say what you should do because servicing a bike is a personal thing. Some people aren't mechanically inclined while others just don't have the time and others just plainly don't want to fool with it. Different for everyone.
I can tell you what I did and now do. I had the dealer perform the 1,000 Mile service just to be safe. My dealer charges $300. I paid $220 because I changed my own oil and filter. I wanted Mobil 1 20W-50 V-twin oil in there
Now I do all servicing myself.
Old May 22, 2013 | 02:41 PM
cHarley's Avatar
cHarley
+1 - I do all of my own service, but at the 1K, the dealer is signing off that everything on the bike is up to factory spec. Having their signature on that 1K mile work order may save some headaches later if you have warranty issues.
And for future reference, a FREE 1,000 mile service is something that can usually be negotiated into the sale when you purchase the bike.
