general "timing" and map question post 1250 conversion...
Old Jun 15, 2013 | 09:50 AM
  #41
rickss69's Avatar
rickss69
Originally Posted by xhellionx
Well, I may have spoken too soon. Bike still getting to 380f with Mich's map. Ran a different map for comparison and same temps. no matter what i do, the ET's just wont stay consistantly below 400. Hopefully the dealership can figure it out and get a good tune on the dyno minus the heat
What I'm really finding out is that the bike will stay pretty consistent heat wise if I'm cruising at 50+. It'll stay below 360f usually then. The temps really only climb when I'm going 40-45mph in 3rd gear at 3000-3500rpm (basic cruising speed on normal city streets). When I'm in that range, the temps soar to 380-400+. The bike also tends to cool down when I'm stopped at lights, etc.
Just for giggles I would change all the afr blocks to 13.8 or so in those partial throttle blocks and see what effect it had. What afr's are reflected there currently?
Old Jun 15, 2013 | 10:48 AM
  #42
IronMark65's Avatar
IronMark65
3rd Gear
xhellionx, you and I have exactly the same problem. I'm going to take rickss69's suggestion and set the afr to 13.8 in the 'problem' range.
I'll report back once I get back from my latest ride.
Old Jun 15, 2013 | 11:51 AM
  #43
IronMark65's Avatar
IronMark65
3rd Gear
Better, maybe. Temps stayed around 380F after 40 min ride. Going to set the 'cruze' afr range cells to 12.5 and try again. I'll report back.
Old Jun 15, 2013 | 12:39 PM
  #44
rickss69's Avatar
rickss69
12.5 is way too rich...even for WOT. I was just trying to determine if it was running too lean at partial throttle. I would next try moving the timing up and down in those cells to see what effect that had. If your tuner has the ability, disable the knock sensor temporarily while making changes. I would even go so far as to disable the O2 sensors and force the engine to accept the afr's without interference until I found the root cause.
Old Jun 15, 2013 | 01:07 PM
  #45
IronMark65's Avatar
IronMark65
3rd Gear
Rick, 12.5 lowered my engine temperature even more. I'd say I averaged just over 370F.
My next ride will be with a Hammer supplied map, that I have 6 or so autotune sessions done on, with the afr modified to 13.8 in the 'problem' zone for the first run, 12.5 or maybe slightly higher for the next.
xhellionx, can you try the same modification to the afr in the 1750 - 3500 rpm, 30 - 40 map range?
Old Jun 15, 2013 | 01:11 PM
  #46
rickss69's Avatar
rickss69
We need to find the problem still Iron...no motor needs that rich of a afr in cruise conditions to prevent overheating. 13.8 is really outside the norm. We need some input from other 1200 owners to get a feel for how far outside the normal range your bikes really are.
Old Jun 15, 2013 | 01:43 PM
  #47
IronMark65's Avatar
IronMark65
3rd Gear
Good point Rick. My Hammer tune has lower timing in the cruise range than the one I was using from xhellionx. It will give us some insight into the effect of lower timing with increased fuel. Maybe the lower timing will allow for a decrease in the afr tables. It's all about trial and error at this point.
Glad it's Father's Day weekend, that give me opportunities to ride. Just hope the weather holds.
Old Jun 15, 2013 | 02:03 PM
  #48
rickss69's Avatar
rickss69
Yeah, I just swapped a clutch and I'm waiting on the mail for a clutch cable myself. When I get it back together I'll go for another ride/record session and see what temps mine show for comparison.
EDIT: Ride showed a max temp of 311 degrees. Of course mine is still a 883 and may have no bearing on your temps without others input.
Old Jun 15, 2013 | 10:36 PM
  #49
xhellionx's Avatar
xhellionx
Rode today a little harder since the break-in miles are done. First things first: LOVE the power now, almost makes all of this heat trouble worth it, lol. Still got to 380, although hit some freeways today so expected higher temp. To answer an earlier question, my AFR in the meat of the map is 14, per Mich's most recent table.
Here is something I feel I need to mention: I've been researching this heat issue for weeks and what I mostly found, is that OLDER model Sporties tend to run cooler, ie less than 320F. I've read that the NEWER Sporties (2012-2013) seem to run higher, ie 340+. Not sure why or if this is even accurate but read up on it and you may come to same conclusion. Still, 380 is not normal from what I've read but I have read some people in this range still.
Like I stated before, I have an appt with Harley on the 26th. They are going to do 1000mile service, dyno and tune with my PowerVision Pro, and diagnose heat issue. It is going to cost a fortune but hopefully I'll have answers. I'll report back.
What year is yours?
Old Jun 16, 2013 | 06:28 AM
  #50
rickss69's Avatar
rickss69
What year is yours?
Mine's a 2007 -
