Sportster exhaust questions
Old Aug 22, 2005 | 02:53 PM
Gary C.'s Avatar
Gary C.
Default Sportster exhaust questions
I've found a set of exhaust pipes I like in a catalog.
They are upswept,and I can also get fishtail tips that will fit on them.
I don't see a crossover pipe with this set,and also don't see mufflers.
How will this affect the way my Sporty's engine runs,and the power band?Will it be too loud,or cause any problems?
The bike is currently bone stock.It is a 2003 with 1700 miles on it,883 engine.
I am also planning on getting a Screaming Eagle air cleaner kit very soon,and will probably bump the engine up to a 1200 next year.
Any advice/comments welcomed.
Old Aug 22, 2005 | 06:40 PM
xlrider's Avatar
xlrider
Default RE: Sportster exhaust questions
It should not effect it in any negative way.
Old Aug 23, 2005 | 02:43 AM
mikeisglidn's Avatar
mikeisglidn
do youknow what is the length of the pipes? and can you post a pic? if the pipes are too short, theyll be loud, which is not a real bad thing, but you may suffer in performance caused by lack of back pressure. once you turn that puppy into a 1200 the added compression will help a lot. be sure to install a set of power cones! have fun send pics!!
Old Aug 23, 2005 | 03:15 AM
Gary C.'s Avatar
Gary C.
Here is a pic of a Sporty with the pipes installed.
They are long,so maybe backpressure won't be a problem.
I have no idea what power cones are.Would you please elaborate?
Thanks.
[IMG]local://upfiles/3820/2F6D359E6D144B1C84D79265330FABCA.jpg[/IMG]
Old Aug 24, 2005 | 03:48 AM
mikeisglidn
look in the exhaust section and there is a post on power cones, skip is the resident guru on that subject!! by the way you souldnt have any problems with those pipes and they look good!
Old Aug 24, 2005 | 12:37 PM
Gary C.'s Avatar
Gary C.
Thanks,I'll check out the Exhaust section.
I think those pipes would look better if they had more space between them where they upsweep,like a Big Twin would have.
Maybe that wasn't feasable in this situation.
Gotta have fishtails on it,too.
Old Aug 24, 2005 | 01:54 PM
12Stones's Avatar
12Stones
Not sure if a Sporty is long enough for that look but, hey, to each his own right? Let us know what you end up doing.
1st time HD owner
Oct 12, 2017 08:59 PM
mthew96
Aug 29, 2014 03:12 PM
MK1200C
Oct 19, 2011 08:46 PM
sportster2009
Feb 11, 2010 07:16 AM
Fletch19
Exhaust System Topics
Oct 2, 2008 08:15 PM
