Otherwise if you just flipped them in their original positions holy cow they'd be a foot or so apart and you'd have a great view of the front and sides of your fuel tank!
=8^)
Not necessarily. If they aren't touching the tank and he didn't switch them then they are facing to the front. lol
From: In the foothills of southwestern NC - US of A
I thought the same thing and it was driving me nuts visualizing it until I just checked my own bike and they can be flipped on the same side and rotated. 'Can't see much of anything useful though!!
I have 28" 15 degree drags on the 4" curve risers and my mirrors are flipped and I can see better for sure, but like was said it take alot of adjusting to get them right.
I couldn't see properly with the mirrors I had so I replaced them with the split vision mirrors and they're good. They take a bit of getting used to but you can see behind you with them.
LMAO. When I had mine on top of the bars, all I could see were my shoulders. moving under helped a lot. and I have drag bars on 6" risers. And just riding with the one on the right side. Broke the other one.
But seriously, I'm 6' also and even at my 220+ weight and with my ahem, slightly protruding belly, I have no problems seeing what's behind me in both of the flipped mirrors on my '09 Iron. But I mean let's face it, there's not an aweful lot of mirror real estate there anyway, making your final adjustment a real sweet spot! As far as I know the bars AND mirrors on both our bikes should be the same, so...
Anyway, I'd try them again in the flipped position and make sure that the stems are physically out as far as they can be [perpendicular to the bike] then slowly and patiently make your adjustments to the mirrors. If you still can't see like you should then you can always purchase the longer stem black mirrors from the MoCo, they're $34.95 each, or of coarse go aftermarket for less/more I suppose. I know, 'prolly not the answer you wanted to hear but at least you have those options.
=8^)
When the 48 was introduced, I tried flipping my long stem mirrors.
I couldn't find an angle that worked.
I think the longer stems were the problem.
I also flipped my mirrors on my Roadster with stock bars and 1" risers
the only issue I have is that I need more head movement to get a real good view of everything, I don't mind around town but on the highway with my fullface it's another story
but otherwise I agree once nicely dialed in I see more of the road with them upside-down
