Underslung Swingarm Design
Old Jul 21, 2013 | 04:30 PM
motohaid's Avatar
motohaid
Originally Posted by c0jones
The reason for combining the sprocket & rotor is so both are on the less visible left side of the bike.
Are you going to move the kickstand & front brake to the right side?
The reason for using a sprocket brake in my case is to clean up which ever side I can. With a sportster the drive side is on the right and there Is nothing that can be done about that. "Move the kickstand to the right side", you are joking, right?
Old Jul 21, 2013 | 04:35 PM
c0jones's Avatar
c0jones
Not joking. It's been done before.
Old Jul 21, 2013 | 06:04 PM
DrewBone's Avatar
DrewBone
From: In the foothills of southwestern NC - US of A
Originally Posted by PanHeadRich
However he did say that he'll probably add some drilled gussets to a couple of stress points. Also keep in mind that HD used round swingarms on the earlier Sporty's and Big Twins. So no doubt that it can be done successfully.
Big Twin Swingarm
Sportster Swingarm
Yes, but look at the % of tubing present in both examples...round tubing only represents approx. 50% of the design in your first example and even less in the second; forged/cast parts make up the remainder of the swingarm[s] and are stronger by inherent design shape than "straight" tubing.
The round tubing I think will lead to unnecessary flexing, and the OP doesn't explain how he's going to get those bend radius' either. Weld together pipe fittings, or? IMHO rectangular tubing of sufficient wall thickness would be a better material choice for the sides than round tubing [with weld joints properly prepared/champhered before being welded together by a skilled craftsman for 100% penetration] to make up the desired shape, and to accurately position & attach the separate parts required to mount the axle, shock mounts, and swingarm pivot.
=8^)
Old Jul 21, 2013 | 06:53 PM
motohaid's Avatar
motohaid
That would be as strange as the Triumph I once had, brake and shifter on wrong sides. POed my friends that tried to ride it.
Old Jul 21, 2013 | 07:41 PM
motohaid's Avatar
motohaid
=8^)
Square or rect tubing is strongest along the "x" and "y" axis. I think round tubing of adaquate size and thickness would probably better resist flexing (almost all aftermarket wide tire swing arms are constructed using round tubing). I wish I could find out what the properties are of the steel used in Harley swingarms because there are metals with better properties at not much more cost. I would say Harley probably designs the swingarms using steel that is adaquate with a safety factor but not with the best properties to save $$. I would try to make as many of the angles as possible by making mandrel bends with as few welds as possible. Even with full penetration beveled welds, cuts and welds are places for a chance of a catastrophic failure and would be limited. I hope to get a chance to work on the design more this week and have an engineer look at my design. I don't have all the forces I need to have it engineered correctly so any help from an engineer I can get will help and then beef it up to the 10th power!
Old Jul 21, 2013 | 08:06 PM
motohaid's Avatar
motohaid
Originally Posted by oh_yeah
Certainly it can be done but please note that the earlier swing arms were short compared to the sketch of the OP. As I noted, stiffness is related to the length of the swing arm to the third power. Besides old Harleys were not exactly notable for good handling in turns - except for flat trackers
In fact the swing arm in the photo posted may even be even shorter than a modern rectangular cross-section swing arm (perhaps due to smaller tire diameters ?). Just visually estimating the length, it seems about 25% shorter which would more than double the stiffness.
P.P.S. Looking again at the old swing arm design above I noticed that the length of the round tubing is only about half the length of the swingarm - beefy steel forgings at both ends make up the rest of the length. That's a typical design example of the fifties and sixties, as I recall and my two British thumpers of that era had similar swing arms. The short length of the tubing kept flexure to a minimum - probably three or four times the stiffness that I originally estimated.
Gussets MAY help with stress although stress really isn't a problem anyway providing that the tubing is of adequate diameter and wall thickness. The problem is flexing as related to handling. BUT gussets, unless they are applied properly to the appropriate areas, frequently INCREASE stress. (Do a search for "stress risers".)
Modern swing arms, or any old ones that I can recall, didn't use gussets in the design except for the axle fishtail; with the possible exception of horizontal gussets on the "U" section at the front of the swing arm.
As mentioned previously, if the intent is style rather than handling then it's strictly a matter of personal taste and the amount of risk the rider chooses to take. I simply point out the problem - not to create conflict but because the OP requested constructive comments.
P.S. These are probably good reasons why a configuration like the original sketch hasn't been successfully done before -
The round tubing used in older swingarms was welded, not extruded mandrel tubing and is more likely to fail. I would put a gusset at the "U" section at the front and a gusset on each side where the tubing makes the turn to the back between the down section and the horizontal.
I have a very concise write up about swingarms that I will post a link to when I find it. In this article the writer talks about gussets and trusses. I have seen a lot of swingarms designed with gussets or truss design.
Old Jul 21, 2013 | 08:50 PM
oh_yeah's Avatar
oh_yeah
Square or rect tubing is strongest along the "x" and "y" axis. I think round tubing of adaquate size and thickness would probably better resist flexing.
..... because there are metals with better properties at not much more cost. I would say Harley probably designs the swingarms using steel that is adaquate with a safety factor but not with the best properties to save $$.
.... have an engineer look at my design. I don't have all the forces I need to have it engineered correctly so any help from an engineer I can get will help and then beef it up to the 10th power!
Hi, motohaid, I'm an engineer.
There are a few problems with the assumptions that you made above (I've redacted parts that aren't important to the engineering aspects of the discussion).
Regarding the relative bending resistance of round versus square tubing of equivalent dimensions square tubing is about 20% better and the axis (X or Y) makes little or no difference to flexing.
Rectangular tubing is more desirable than either because it can be made stiffer in the dimension that is subjected to maximum load.
Regarding the properties of the materials (within the elastic limit, which all materials MUST conform in this discussion), flexing/bending is related to a property called Young's Modulus or Modulus of Elasticity.
For weldable mild carbon steel, this value is constant at about 30 million pounds per square inch. What this means is that flexing/bending of steel members (unless the steel is Chinese-made, LOL) is constant and independent of the steel alloy selected and how much and who paid for it.
Insofar as mandrel-drawn and welded construction, there is no difference between the two since Young's Modulus is the same for carbon steel. Stress and failure should not enter into a discussion like this one - if that is a concern, you are in over your head.
You asked for comments, both positive and negative and that you want an engineer to look at the design. I've given you my opinion, what you do with the information is up to you.
I have zero desire for confrontation, as I mentioned earlier. I wish you luck and will leave this discussion with one last suggestion: do not rely on my opinion or anyone else whose qualifications are unknown. You get what you pay for !
Cheers
Old Jul 21, 2013 | 09:06 PM
DrewBone's Avatar
DrewBone
...Even with full penetration beveled welds, cuts and welds are places for a chance of a catastrophic failure and would be limited...
I started my employ with Grumman Aerospace [now Northrop-Grumman] in July of 1978 in the capacity of a welder/fabricator and during that time I've had the oportunity to work with all the welding process' and most if not all of the alloys both ferrous and non ferrous. And I can say without a doubt that properly prepared weldments, undertaken using the proper filler rod for the base material used, and performed by a skilled and properly trained welder, can produce strong, resilient, and long lasting products.
In this line of aerospace work there is no room for error, yet there are many things that are welded. For instance, the hooks on the Navy planes that get catapulted off the deck of our aircraft carriers, and the tail hooks that catch them as they land full throttle. There is an unimaginable array of items that we take for granted on a daily basis that are welded, yet we don't ever think about any "catastrophic" results...unless of course we're talking about some garage welder with his almighty Harbor Frieght welding machine attempting to weld a trailer hitch on his bud's duelly to tow his $250,000 motorhome...then we'z talkin' catastrophy for sure!!
You mentioned the HD swingarm...have you noticed how many individual pieces make up this swingarm, and how much of it is welded? Is it doomed to failure because...OMG, it's welded? Hell no. Yet it's design began like anything else; it has a specific purpose. The engineers at HD said to themselves, "Ok, this is what we need, now how can we make it?" And they did. Then the beancounters said, "Ok, now that you've made it, how can we make it cheaper?"
The questions that followed I'm sure went something like this: [engineer #1, under his breath] "These ****ing beancounters always find a way, don't they?! Just how in the hell are we going to make this thing cheaper?" Engineer #2 says..."Well...let's look at the properties of this material, see how light we can go with it to endure any possible stress applied upon it, figure out some shapes, do some tests, then take it from there." Engineer #3, "M'kay, let's get started!"
When all was said and done the newly designed swingarm passed muster with engineering tests and ultimately with the beancounters and boom, into production it went. And just a wonderful symphony of steel it has proven to be too. I'd even venture to say that it's designed to handle at least twice any operating load, to protect their asses, and just for shitz'n giggles. And I say this from manufacturing experience, as our engineers ALWAYS designed most everything we ever made to handle at least twice it's rated capacity, whether it was a 10 ton overhead bridge crane, 26'x12'x4' .250" wall & .375" thick stainless steel chem mill tanks wrapped with 21" and 18" I-beams, to hangers for a platform suspending a 1 ton transformer...
I never knew this until you mentioned it, but is there a reason why "most" aftermarket swingarms are made from round tubing? Well, I couldn't answer that, but I could guess. All I know is there's gotta' be a reason why the MoCo choses to go another route, probably from experience I would imagine?!
In any event, I still think that for an overall smaller footprint, less weight and more rigidity, rectangular tubing and welding is the way to go for your project. I can't see you making those tight radius bends in your drawing with any kind of "usual" mandrel, it's just not possible. But you will see through it, just like anything else, as there will be design changes as you go, it's just part of the process!
Eagerly awaiting your final product!
=8^)
Old Jul 21, 2013 | 09:22 PM
motohaid's Avatar
motohaid
Cheers
If you felt I was being confrontational that was not my intent. I just felt we were having a conversation and was expressing my thoughts.
Old Jul 21, 2013 | 09:31 PM
oh_yeah's Avatar
oh_yeah
I was bowing out of this discussion until I saw the post by DrewBone - a good summary from an experienced journeyman welder !
motohaid, I didn't feel that you were confrontational - I was concerned that I may have been considered confrontational. Written stuff doesn't come across that well and my writing tends to be - well, formal
Cheers, best wishes, success in your project and be safe !
