What Maintenance is Recommend for a Bike that sat
As for using it in the gas tank? I add it to a tank a few times a year. I add Seafoam to keep things in order.
I have lots of cleaner for my Bike. Okay making a list of all I need from all the advice and will post it in case anyone sees anything wrong. Then I can start buying!
Online Buying List so far (Amazon)
http://screencast.com/t/xGWM5JjGs
Need to Buy Local
Oil (6 quarts) 20w-50 synthetic Mobil1
Front Tire
Gas
Vacuum lines (If I don't have already)
Todo List:
• Oil Change & Filter change (3 quarts) 20w-50 synthetic Mobil1
• Add Seafoam to the gas tank and oil tank (ride 100 miles and replace oil & filter again)
• Carb rebuild
• Air Filter replacement
• Spark Plug and Spark plug wire replacement
• Lube all Cables (Dry Graphite)
• Lube choke (Dry Graphite)
• Check and/or replace Vacuum hoses
• Check all fasteners are torqued to spec
• Check clutch, primary chain, and belt tension
• Brake Fluid replace/flush (18 oz) - Dot 5
• Replace both tires
• Replace Tranny fluid (32oz) Mobil1 75w-90 gear oil
• Drain and Replace Gas
• Chrome cleaner on Rear springs (rust)
Need to Buy Local
Front Tire
Gas
Todo List:
Carb rebuild
Replace both tires
In all, this list can be knocked out in a day.
Yeah, that is about what I figured. Time is my biggest enemy cause I just have none. Hence why it is end of July and I'm finally looking at doing it
So hopefully I can carve out a weekend to just get it done, along with a nice wash.After this I have a few things (non-maintenance) I want
• New floor board/pegs
• Replace the locks on my saddle bags since they are cracking
• New battery cover, since mine no longer latches and love to fall off while riding.
BUT first it must be a happy bike
Thanks everyone again!
Thanks everyone again!Ride safe.
