Ironhead Oil
Old Jul 27, 2013 | 02:52 PM
xBigMarkx's Avatar
xBigMarkx
Default Ironhead Oil
I am doing the final assembly on an ironhead project. I want to put to start it and see if things are together correctly. is it ok to use 20w50 walmart oil for now? I don't want to spend 8 bucks a quart on harley oil because i might be draining it out and taking it back apart. Is 20w50 oil the same for cars or bikes? I will change it later before riding the bike more than around the block. thanks Mark
Old Jul 27, 2013 | 03:24 PM
Scuba10jdl's Avatar
Scuba10jdl
If it were me, I'd run straight 50-weight, but that's a controversial topic. If you haven't already, check out THIS THREAD on XLForums for a nice write-up on oil changes for the Ironhead.
Old Jul 27, 2013 | 03:26 PM
grbrown's Avatar
grbrown
Mark, there are more oil experts where Harleys are concerned than there are grains of sand on the planet! So take great care when asking questions!!!!
Check your factory service manual. For modern Harleys we are told to use an oil for diesel engines, when 'approved' motor oil is not available. So by all means visit Walmart or other cheap outlets, but look for diesel 20W/50, that meets specifications CH-4, CI-4 and CJ-4.
If you are able to find some, there will be no need to throw it away, as it is to spec. Hope that helps!
Old Jul 29, 2013 | 10:49 AM
skipperhd1's Avatar
skipperhd1
Cool harley oil
over the years, i have always used harley oil, i have had problems with my bikes over the last 40 years, but never because of the oil. cheers from montana
Old Aug 3, 2013 | 08:10 PM
83XLX's Avatar
83XLX
Wallyworld 20w50 car oil is fine for a startup and a bit of running/test riding. I wouldn't ride the bike long term with it in there, though. In warmer weather, I'd run straight 50wt (or 60wt) Harley oil. In the winter, Harley 20w50. That's what I've used in my Ironhead for the past 23 years...
tmilo1000
Apr 17, 2017 05:05 PM
Scudda
Oil Archive (no new posts)
Mar 23, 2017 09:32 AM
harley1584
Mar 19, 2012 07:17 PM
r0ck3r
May 24, 2010 09:50 PM
OnTheRoadinAZ
18
Jun 11, 2006 10:30 PM
