I just got done installing some V&H pipes on my Iron 883. i tightened everything down and when i went to the left side of the bike to connect the O2 sensors i noticed that there was about 1/8 inch (completer guess, it's between an 1/8 and a 1/4) of screw left for the Flange to fit flush against the heads. The problem is that i can not tighten them anymore without the fear of stripping something. does the flange have to be flush or can there be a bit of screw left behind it. I tried my best of tightening everything together and not fully tightening one at a time.
No, the flange does not need to be flush. Get the correct torque and you're done, provided it doesn't leak.
Thanks for the help. Just found a thread on here on how to check for exhaust leaks so that will be the next thing on my list as soon as I get home from work.
care to share the method for checking? I think i might have a similar problem at the flange
