I'm kind of embarrassed about this one and I feel really STUPID!
Yesterday I was removing my old pipes to install my new ones (2011 Nightster). I was following an installation guide, because I have zero exp in doing this. And it said "Remove the belt cover...". And guess what, I removed the "cam cover??/big front right side cover" (I can be wrong about how it's called).
And yeah, in no time my "whole" working space was covered in oil! So...
1. What's the oil for?
2. Can I just refill via the oil tank cap?
3. Do I need to see a dealer to fix it? Or isn't it as bad as it looked?
The oil is engine oil, trapped where you found it to lubricate the cams. No harm done! If you have bolted it back on and the gasket is not damaged you can indeed top up your oil, as per your handbook. You may find the amount lost hardly shows on the dipstick, but I could be wrong. Oil goes an awfully long way when it gets the chance.
Now go and buy a factory service manual, so you don't make any other mistakes!
Your cams didnt pop out or become maladjusted did they? That usually happens when you remove the gearcase cover. It can be very tough to reinstall if there is any sort of misalignment in the cam journals.
I hope this isn't your case as it requires disassembly of the rockers to reinstall properly.
You're good, no worries. Scuba is mentioning basically worst case scenario. Even taking off the cover entirely, it's rare that I've ever pulled the cams out. You most likely had rocker pressure on the rods which would've held the cams in place anyway, with the amount you pulled.
again, chalk it up to a learning experience and an idea of what your "shop" needs per the mishap, i.e. motorcycle oil pan, oil absorbtion materials, towels, and some patience
