Charging system
Old Sep 3, 2013 | 10:34 AM
glennt7's Avatar
glennt7
Default Charging system
My 91 sportster stopped charging. New battery and reading only 12.7 volts when running. My question is what could it be AND WHERE IS THE ALTERNATOR. Is it the starter combined with alternator or is it somewhere else?
Thanks
Old Sep 3, 2013 | 02:00 PM
parabellum_9x19's Avatar
parabellum_9x19
Thanks
It is called a "stator" and its a halo of wire coils buried very deep into your primary case.
Replacement is a BITCH. You will need a tool to hold the main gear assemblies from turning while you apply CRAZY torque to the main nut. You can use a 4" brass doorhinge for this.
You will also need at LEAST 4 foot of breaker bar and more than one 200lb man to apply enough torque to remove the main nut. That nut is set to 250ft*lbs from the factory, plus red loctite. It will NOT come off without a fight.
Once you pull all the primary gears and chain off (they usually come off as one assembly once both main nuts have been removed) you will see the stator behind them.
Here is a picture showing the stator (that halo looking thing on the left, around the main drive shaft) after you have removed the main shaft nut (and the other shaft nut) and then removed the entire primary gear set + chain as one piece:
This is one of a handful of jobs that I would actually pay a skilled mechanic to do for me.
Old Sep 5, 2013 | 07:57 PM
Scorpza's Avatar
Scorpza
I agree with you on that one. I've done it on a old scrotch rocket and it's a BIAAATCH of a task. I'd rather shell out a few dollars and have a cold beer while waiting.
Old Sep 5, 2013 | 08:40 PM
Scuba10jdl's Avatar
Scuba10jdl
You're gonna want to check out my thread HERE for an idea of what needs done.
And the other guys are correct, it is work.
Old Sep 6, 2013 | 06:08 AM
cajun555's Avatar
cajun555
Do a search on these forums and check out the stator first. You'll have to have VOM meter to check out the stator. Takes about 15 minutes. Check out all your grounds and connections.
Just went thourgh this on a 01 sporty, stator checked out perfect; put on a new regulator and all good now. A lot easier to replace regulator than stator
Old Sep 6, 2013 | 08:53 AM
parabellum_9x19
Awesome, awesome, DIY thread thank you for posting that.
AK97fxdwg
Aug 27, 2014 01:02 PM
prost34
Jun 23, 2011 12:31 PM
2000hardtail
EVO
Oct 18, 2010 03:14 PM
TRVSDAD
Jul 23, 2010 07:20 PM
79lowrider
Oct 2, 2008 08:10 PM
