It is attached to the rear fender with double stick tape.
Many just grab it and pull hard to remove it. Else, you can heat (w/ a hair dryer or heat gun) the underside of the reflector where it attaches to the fender, to release some of the glue bond, and again grab and pull
If any glue or tape residue remains use 3M Adhesive Remover. WD40 may work too.
