48 riser question
Old Sep 28, 2013 | 07:41 PM
201348hd's Avatar
201348hd
Default 48 riser question
I'm looking to put a set of HD drag bars on my 48. I don't want to be leaned over so much so I'm trying to find risers about an inch and a half to two inches. I want to retain the stock speedo location though. I have searched and I'm striking out or I'm missing something on how it works. Any info would be greatly appreciated.
Old Sep 28, 2013 | 07:59 PM
c0jones's Avatar
c0jones
The speedo bracket is part of the handlebar clamp,
so raising the drag bar will raise the speedo.
I don't understand why you want to raise a drag bar.
Why not get handlebars that are the height you want?
Old Sep 28, 2013 | 08:04 PM
201348hd's Avatar
201348hd
I don't wanna raise it that high. Around an inch and a half. I like the look of the drag bars. I'm just not sure of how uncomfortable it will be with forwards and the spring seat. I may just jump in and give it a shot though.
Old Sep 28, 2013 | 09:11 PM
huyrua's Avatar
huyrua
Try loner industries. They make 1" and 2" risers that retain the stock speedo.
http://lonerindustries.com/
Old Sep 28, 2013 | 10:06 PM
201348hd's Avatar
201348hd
Thanks, that's exactly what I had in mind
Old Sep 29, 2013 | 06:19 AM
Rog48's Avatar
Rog48
You may not have a choice, several bars hit the fork caps so you either have to lower the forks or get spacers for the bars.
Old Sep 29, 2013 | 08:45 AM
rickss69's Avatar
rickss69
Getting rid of the silly top triple tree with this Joker Machine replacement...available in black as well.
Old Oct 1, 2013 | 05:34 PM
c0jones's Avatar
c0jones
I like the 48's top triple tree.
I think they look silly with Loner risers,
just use bars 1 or 2 inches taller instead.
Fewer parts/bolts is better.
Old Oct 1, 2013 | 08:43 PM
OldSchoolZ's Avatar
OldSchoolZ
You honestly don't even need the risers. Yes, they are going to be a little lower but it is not that much lower than stock. They also have a pullback which helps with the height. My advice, get the bars first and mock them up before you start messing with the riser situation. I just installed 24 inch drags on my 48 and due to the width, I had to go with 2 inch risers so they would clear the tree. I purchased the Joker Machine triple tree (just like the one above) which enables you can use traditional risers. Great piece. I personally think the Loner Industries risers for the 48 look weird when on the bike.
Old Oct 1, 2013 | 09:29 PM
huyrua's Avatar
huyrua
I'm currently running drag bars on my 48. I'm looking to get the loner industies 1" riser so the bars will clear the tree. Another reason I'm going with the loner risers is that I wanted to keep the stock dummy lights.
