Help!! Bike won't move
Old Oct 30, 2013 | 07:23 AM
gilmour68's Avatar
gilmour68
Default Help!! Bike won't move
I last rode my bike to work last Wednesday and everything was fine. This morning I planned to ride to work as well, but ran into a problem. I started the bike and let it run with the enrichener pulled all the way out while I put on my gloves, helmet and glasses. I pulled in the clutch, pressed the shifter down into first gear and heard the typical thump followed by a ratcheting sound. When I released the clutch lever the bike didn't move and I heard a "whirring" sound.
I slowed the idle a bit, popped it into neutral, back into first and tried again - same result. I shut the bike off, restarted the engine and tried yet again - no movement. I also tried moving up to second gear, same thing. I had no time to mess around with it so I pushed it back into the shed, parked it and took the truck to work.
Any thoughts on what may have failed? The "N" indicator goes on and off when I shift into first or second, but the bike doesn't move at all. Could this be a failed clutch? Thanks for any suggestions.
Old Oct 30, 2013 | 07:29 AM
cHarley's Avatar
cHarley
Broken belt would be the first thing to check.
Old Oct 30, 2013 | 08:24 AM
rhythm1978's Avatar
rhythm1978
Yea. I'd check the primary and clutch. I would think it has to be one of the two.
Old Oct 30, 2013 | 10:09 AM
gilmour68's Avatar
gilmour68
Hey cHarley,
Are you speaking of the main drive belt? If so, I think it's fine but I'll check it anyway. Is it possible the clutch plates gave out? It sounds like something's spinning in the primary but no power is making it to the rear wheel.
Old Oct 30, 2013 | 11:05 AM
BrainsB4Beauty's Avatar
BrainsB4Beauty
Maybe talking about the primary drive chain. Take off the inspection cover (the little cover on the right side engine case) and check that the chain is still tight there. Also, I'd check all your clutch cable and make sure that it isn't hung up somewhere and not fully engaging the clutch. Hearing the 'clunk' makes me think the primary is turning...
Old Oct 30, 2013 | 11:55 AM
John Harper's Avatar
John Harper
Drive belt pulley splines stripped?
John
Old Oct 30, 2013 | 03:55 PM
gilmour68's Avatar
gilmour68
Though I didn't think it would be something this simple, i found the broken drive belt on the ground when I got home. Couldn't see it when leaving at 6 am.
Old Oct 30, 2013 | 06:09 PM
John Harper
At least it broke in a convenient spot.
Detective cHarley solves another one.
John
Old Oct 31, 2013 | 06:00 AM
Rog48's Avatar
Rog48
Strange, most belt breakages I hear about happen at a stop, clutch in, putting it in gear. I wonder why?
Old Oct 31, 2013 | 06:57 AM
Dusty Bones's Avatar
Dusty Bones
Some time between last "wednesday and this morning", is a long time. Just like everything in life when people tell stories, the most important details are always left out.
