Indicator Lights Canadian Version
Old Jan 20, 2014 | 11:43 PM
rkwm's Avatar
rkwm
1st Gear
Default Indicator Lights Canadian Version
Hi,
New member, recent purchase 2014 Sportster 48.
Canadian version.
Motorcycle in winter storage unable to check this until Spring arrives.
Burning question, do the rear turn signal/indicators act as running & brake lights too? Or only come on during signalling?
I have a taillight installed from factory that I think operate as Brake & Running Canadian Version.
1200 kms driven never thought to look and am wondering now since I purchased a smoked lens kit and it raised my curiosity.
Thanks in advance.
rkwm
Old Jan 21, 2014 | 03:07 AM
Triumph Jerry's Avatar
Triumph Jerry
Normally the front signals have a 2 filament bulb. (1 for signal other for running)
The rear has a 1 filament bulb. (signal only)
If yours (Canadian) is different, it would have to be wired completely different and have 2 filament bulbs front and rear.
Your manual SHOULD list 2 different bulb numbers, if it's normal.
Old Jan 21, 2014 | 07:41 AM
24v's Avatar
24v
On the US version of the 48 the rear bulbs are dual filament. However, I just looked at the parts diagram for the 48 and it lists a separate part number for the bulb socket on the Canadian version. I suspect this may be a single filament socket so that the light only operates as a turn signal.
Old Jan 21, 2014 | 09:22 AM
aqcr_28's Avatar
aqcr_28
Not sure how it is for the 2014's. The rear blinkers on the 2013's and prior do not operate as driving and/or break lights; they are only turn signals. The moco does however offer a turn signal module for $75 or so, that will enable your rear blinkers to operate as running/turn signal/break lights.
Old Feb 7, 2014 | 10:53 PM
rkwm's Avatar
rkwm
1st Gear
thanks
Old Feb 8, 2014 | 08:22 AM
Mich's Avatar
Mich
Transport canada does not allow the turn signals and brake lights to be combined. They also do not allow the chopped rear fender and side license plate mount which is why we get the standard sportster fender on the Iron here in Canada instead of the chopped version that is stock in the US.
VinnySem
Oct 8, 2010 10:40 AM
99XL883C
Dec 9, 2007 06:42 PM
jamesf0622
May 21, 2007 10:52 PM
Sammi
Jan 9, 2007 11:32 AM
SimonW
Sep 27, 2006 04:55 PM
