Knocking noise from motor
Old Feb 16, 2014 | 11:45 AM
Zackd's Avatar
Zackd
Stage II
Default Knocking noise from motor
I need some help! I recently changed out my stock AC kit for a Kurankyn Mach2 co-ax kit and rejetted the carb with a stage 1 kit on my 05 883C. Installation went okay, took a little while because I'm new to working on my bike. Started it up and now there is a knocking noise in the motor that was not there before install. Does any one have any suggestions on what to do?
Thanks
Old Feb 16, 2014 | 11:53 AM
Sikk50's Avatar
Sikk50
Does it sound like a sewing machine?
Old Feb 16, 2014 | 12:26 PM
John Harper's Avatar
John Harper
Noises are so hard to diagnose, much less describe. Have you checked for intake leaks, exhaust leaks, fuel tank mount bolts.
With non-stock aircleaner, your bike will make some new noises, new NORMAL noises. Mine sure did with AC and slipons. Better noises IMO.
John
Old Feb 16, 2014 | 10:49 PM
run1fsr's Avatar
run1fsr
None of that should cause a knock provided you dropped nothing in the engine.
Old Feb 16, 2014 | 11:26 PM
06Sporty75's Avatar
06Sporty75
sorry about your problem,, I'm of no help,, but for future reference,,
this is why its best to take it to a trained professional in the first place,, save yourself the aggravation and time and possible damage or being stranded on the road. Any shop would have only charged you about $100 to install all of that..
Old Feb 17, 2014 | 09:16 AM
Scrambler900's Avatar
Scrambler900
What he said. I love it when a customer brings something in that they "tried" to do themselves and made it way worse and more expensive.
Old Feb 17, 2014 | 10:11 AM
John Harper
Looks like some "tough love guys" are on the forum today. Seriously, if all you did was change that superficial stuff, you should not have caused any problems. The stock AC probably muffled a lot of engine noise.
John
Old Feb 17, 2014 | 11:08 AM
OldSchoolZ's Avatar
OldSchoolZ
Make sure the bolts you mounted the air cleaner with have holes in them so air can pass through.
Grappa
Jul 2, 2015 03:48 PM
devlin1963
May 12, 2014 05:37 AM
Zackd
Feb 15, 2014 07:22 PM
98wideglide95632
Jul 17, 2011 09:38 AM
THUMPERRRR
Jun 25, 2007 12:04 AM
