new sportster noticing a rattle
Old Mar 1, 2014 | 05:22 PM
reonimation's Avatar
reonimation
2nd Gear
Default new sportster noticing a rattle
Hey guys and gals!
Picked up my first Harley yesterday. Got the 2014 1200 custom and am loving it.
Starting to notice an odd notice an odd uneven rattle when slowing down or holding in clutch when in 1st gear. If I am in any other gear the sound isn't present. It sounds like a small pebble in a soda can vibrating.
I only have sixty miles on it and a call to the dealer suggested its noises from the break in and call back if its still happening after 150 miles.
What do you guys/gals think?
Thanks a lot.
Old Mar 1, 2014 | 05:46 PM
chappy99's Avatar
chappy99
Do what they tell you,it is under warranty.
Old Mar 1, 2014 | 05:51 PM
bighosschato's Avatar
bighosschato
Take it back!!!!!
Old Mar 1, 2014 | 06:01 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
I assume you are sitting still holding in clutch when in 1st gear. Get someone to do it and walk around and listen. Get you a good both ear stethoscope and probe it all over. Now would be a good time to hear what all the spinning internals sound like. My bet is it's nothing more then the start of the exhaust stroke when the valve just starts to open. It sounds like that since there is some rushing out gas expanding into the dual crossover exhaust baffles. (each cylinder use both exhaust pipes on each fire and the cylinders fire one at a time apx two strokes apart since they reach the top a few degrees difference. That replaces the slow potato potato sound of old with th FI 1000 rpm idle rasp. However ask the experts but you personally need to become the expert in charge. There are some real sharp Sporty experts on here.
Old Mar 1, 2014 | 06:45 PM
reonimation
2nd Gear
The sound happens while the bike is in motion in first gear with clutch pushed in coming to a stop.
KerryS85
Mar 20, 2016 01:38 PM
Ride Hard 1
May 6, 2012 03:55 PM
asahi1234
Oct 30, 2011 08:01 AM
daveMD2011
Jul 17, 2011 06:34 AM
jackietan
May 28, 2008 10:14 AM
