Progressive 11-1527
Old Apr 19, 2014 | 08:15 PM
Jester 08 Nightster's Avatar
Jester 08 Nightster
Default Progressive 11-1527
I finally got around to pulling these springs off the shelf and installing them in the 1200N. I also swapped out the factory oil for some Belray 10 weight while I was in there. The process wasn't too involved, but I was glad to have to buddy on hand to keep the bike upright and drink a few beers.
The verdict is an immediate improvement in ride over railroad tracks and going over road transitions that had bottomed out the previous set up. I've absolutely hated the 'thunk' of that terrible factory set up. Why would the MoCo put a 10" steel tube in a place where wound coils belong.
Is it perfect, no I'm sure it could be better. But after adding 1.5" to back with longer shocks, and now with the 11-1527's in the front the bike is riding like it should have when it rolled off the assembly line. If you're on the fence about this upgrade, do it, you'll be happy you did for little $$$ spent.
Old Apr 20, 2014 | 03:33 PM
Alpha Mike's Avatar
Alpha Mike
I did the same yesterday, big improvement I agree. How much air gap did you leave above the oil?
Old Apr 20, 2014 | 06:49 PM
Jester 08 Nightster
140mm with the forks 100% compressed, right off the Progressive instructions. I know the service manual calls for more oil, but I gave credence to the fact the new coils are thicker and more tightly wound. I used the full preload spacer as well.
Had it out again today, I'm pretty happy with the set up now.
Old Apr 20, 2014 | 09:17 PM
slyedog's Avatar
slyedog
Per progressive minimum is 5.5" iirc. My manual was factory 5.75". I went 6". Between the different sportster models some will have different spacer length and most likely oil depth. Use good judgement and you will be fine.
Old Apr 20, 2014 | 09:39 PM
Alpha Mike's Avatar
Alpha Mike
Thanks, I went with 150mm just to be safe. I was more curious if I was missing out on a touch more compression. I definitely don't want to chance blowing out seals though, our roads suck right now after the winter and the forks are really getting a work out.
Old Apr 21, 2014 | 08:48 PM
Jester 08 Nightster
Roads in central Pa are terrible as well. This past winter was real hard on them. The majority of local roads should be completely resurfaced. I'm looking forward to heading south in June to the Blue Ridge.
vern58
Apr 2, 2016 08:44 AM
baka1969
Mar 15, 2013 04:52 PM
fireaxxe
Oct 22, 2011 05:30 PM
GPHDXLC
Mar 18, 2008 01:13 PM
TurkeyRun
Mar 9, 2008 11:21 AM
