I also use the
Badlands lighting module
I'LL-04-RL-C with
Radiantz LED clusters
LED-DR56-Red for the rear. Solid state does not get hot.
No problems at all.
From: In the foothills of southwestern NC - US of A
Custom Dynamics:
Slim Line Custom Dynamics® Signal Stabilizer Sportster
Fits '04 -'13 XL Models and '10 Softail Convertible (2014 XLs Do NOT Require a Load Equalizer) Alarm Compatible, No Heat, No Load, 100% Waterproof5 Year Manufacture Warranty Dimensions: 4.2" x 0.6" x 1.4" Signal Stabilizer XLITEM#: Signal-Stabilizer-XLPrice: $64.95
It plugs directly inbetween your existing light circuit connectors under the seat of your '04 Sportster, with no need to cut/solder any wires. It does however require 12v[+] and [-] connections directly to your battery.
