Help identifying a noise
Old Jun 3, 2014 | 09:48 PM
hOtroDD77's Avatar
hOtroDD77
Question Help identifying a noise
Went on a short ride this evening, and when I got back to the house I noticed my engine was louder than normal. I heard it first when I got off the bike to open my garage, when it was idling. It's kind of a 'clacking' noise if that makes sense. I haven't noticed it before. Anyone have any ideas? This is a crappy cell video, I know. You can best hear it from about the 5 second mark(right before I give it a little rev) through about 15/16 seconds. It was hard to capture because of the bass of the pipes and the normal engine noise.
Old Jun 4, 2014 | 12:11 AM
JeffJA's Avatar
JeffJA
Are you running synthetic oil?
Old Jun 4, 2014 | 12:30 AM
hOtroDD77's Avatar
hOtroDD77
No, still running regular oil. Bike has about 2700 mls. And only mods are slip ons and xied's. I did check the oil when I got in the garage. It was a little frothy, but looked to be at a good level.
Old Jun 4, 2014 | 06:28 AM
mrfikser's Avatar
mrfikser
check for an exhaust leak at the heads/pipe..
Old Jun 4, 2014 | 10:25 AM
hOtroDD77's Avatar
hOtroDD77
I'll check again this morning. After I installed these slipons I checked over, and over to make sure I had no leaks. Had one at the muffler joint, but got that resolved. As far as where the pipes mead the heads, I did everything I could think of to check: closed up the end of the pipes, used smoke, just listened... I looked and don't have any soot around those areas. I'm fairly confident there's no leak, but still not 100% sure I guess. I've ridden several hundred miles since the pipes were changed and yesterday was the first day I heard anything. From what I can tell, it seems to only happen at idle, not when throttle is applied. I plan on taking it to the dealer, just don't wNt them to hassle me about the pipes/xied. Trying to get a little insight first
Old Jun 4, 2014 | 11:16 AM
Van Buren's Avatar
Van Buren
carb bike?
Old Jun 4, 2014 | 11:17 AM
Van Buren's Avatar
Van Buren
forget it, i see your running xied so that would be efi 2007+
Old Jun 8, 2014 | 08:18 PM
JeffJA's Avatar
JeffJA
Default Street bob taillight??
....sorry, wrong thread
Old Jun 8, 2014 | 08:34 PM
JustOneDean's Avatar
JustOneDean
Check the flange nuts on your exhaust studs. They tend to vibrate loose on Sporties.
Old Jun 8, 2014 | 09:19 PM
cvaria's Avatar
cvaria
I literally have a thread running right now trying to get to the bottom of that same noise.
-----here:
https://www.hdforums.com/forum/sport...il-thread.html
cold engine---
hot engine---
