Update: got it working about as good as I can. No overflow no stall just needed to adjust the float to the level in the book. Which I have to say I thought was crazy far but can't complain so far.
the float level is critical as it affects how rich/lean the bike runs to a good extent.....when adjusting (if I remember correctly) you don't need to bend the float itself...just bend the little tang that holds the float needle/valve in place... and the carb. needs to be inlet side down with just the weight of the float on the float valve...this should help..
