Anyone down a chain conversion?
Old Sep 3, 2014 | 01:19 AM
Zenmervolt's Avatar
Zenmervolt
Originally Posted by Proteus
Agreed.
But as I mentioned earlier, it seems the quality of the newer OEM belts is going down those last years.
I use this bike daily to commute to my work, however the weather is, living here in Europe above the rust belt, 80 % of the time on highways at 75 MPH, this may also be a reason why my belt went south at such a "low" mileage...
Besides the longevity of a chain vs a belt, I still trust a chain for its toughness, I rode chain bikes for years, and I never lost a chain on the way, while it seems to happen that belts snap sometimes, without earlier warning.
I also have to say that I put oil on the chain once a week, after having done for about 500 miles there in between. Overkill, I know...
True. And there's nothing wrong with chains. They're quite reliable within their design parameters and their failure modes are easier to notice (kinks, obvious wear, etc.) and rarely fail completely. Though I have had friends who've had chains let go, wrap around the axle, and lock the rear wheel (yes, I know, this is itself anecdotal, I just wanted to point out that crazy things can happen regardless).
Honestly, most of the issues with belts failing early seems to be issues with slight misalignment of the rear wheel or with a rock being ingested. Chains handle small misalignments better than belts.
I'm not really "down" on chains, I just think that belts are generally an improvement under most circumstances and that there are good reasons for using them instead of chains, including expected durability.
Old Sep 6, 2014 | 11:31 AM
laecutter's Avatar
laecutter
6th Gear
Default Chain Vs Belt
Lot of good qualities in both chain and belt. Me after going through two belts on my sport decided to go with a chain. Last belt left me stranded between Big Springs and Abilene wife had to come with the truck and trailer from Dallas. Side note only one person on a bike stopped to ask if I needed help had at least ten cars stop? Any way got home put a chain on it and have not looked back. Just now looking at replacing the system with new chain and sprocket 30K+ miles. I ride to work almost every day no snow or rain if I can help it. Any ways wear dress pants even light color ones no chain lube splatter. Use Belray or Honda spray it on wait an hour usually doing other maintenance/cleaning then wipe everything down. Next morning off to work ( I do not have a chain guard). With the chain never stranded, choice of gear ratios for the way I ride. Only difference is replacement and cost one 30 min max the other (belt) dismantle the rear end. Guys that have switch what are you running gear ratio wise?Me 49/24.
Old Sep 6, 2014 | 12:25 PM
John Harper's Avatar
John Harper
48/21 for mine.
John
Old Sep 6, 2014 | 12:50 PM
Proteus's Avatar
Proteus
I don't know my ratio, the indy did the job, I asked him to keep the same ratio as the belt.
Old Sep 6, 2014 | 12:58 PM
06Sporty75's Avatar
06Sporty75
belts seem better to me, I don't understand why anyone would prefer a chain, I guess it's preference, but what about shaft drives? obviously this is the most expensive to manufacture, and probably why Harleys don't have them. but the shaft drive appears to be superior to everything, no maintenance, lasts forever and best for performance..
I don't know if belt quality has gone down but they are definalty making them smaller now, the latest ones are almost 1/2 the width of the old ones.
Old Sep 6, 2014 | 01:02 PM
vheflin's Avatar
vheflin
Default I don't know chit
about chains but I've got 110K miles on my original belt. It still looks good along with both pulleys.
Old Sep 6, 2014 | 03:49 PM
Zenmervolt's Avatar
Zenmervolt
Shaft drives do require maintenance (have to keep oil in the final drive, the seals tend to wear out with age, etc.) but it's not much. They are heavier than other options by a large amount and they are also by far the least efficient (they have much greater frictional losses than belts or chains). Also, shafts suffer from something known as "shaft jacking" where acceleration makes the rear suspension extend and deceleration makes the rear suspension compress. Newer shaft-drive bikes have suspension designs that eliminate this effect, but they also add weight and design complexity.
Old Sep 7, 2014 | 07:15 AM
Proteus's Avatar
Proteus
About driveshafts, to me, they only are efficient and useful when the engine's crankshaft is lined with it, like on an Airhead or a Guzzi
Old Aug 1, 2015 | 01:53 AM
bob kegogi's Avatar
bob kegogi
Chains are for ease of gear changes, which can be accomplished by a regular garage monkey. Belts to, but you have to buy the right size, vs using a chain breaker. Belts are good for the average rider who doesn't go past 4000 rpms normally. 100 hp buells snap belts. But those are easy to replace, Dynas are a lot more work to reinstall a belt
Old Aug 1, 2015 | 09:10 AM
Cool Inferno's Avatar
Cool Inferno
Saw the damage done to a GSXR 1000 by a broken chain at high RPM and it wasn't a pretty sight. Completely destroyed the rear plastic body parts, put a good slice onto the lower part of the frame. The rider was very fortunate that it did not catch his leg. My take is if you can use the belt drive, stick to it.
