2007 Screaming Eagle Nightster (1200NSE1)
This is the 2007 Nightster Harley Should have built, 1200NSE
(Engine is 10.5:1 compression utilizing stock bore cylinders and pistons)
Harley Davidson Parts List:
Screaming Eagle Race Tuner
Screaming Eagle Pro Performance Heads
Screaming Eagle Performance Cams
Screaming Eagle High Tensile Strength Cylinder Stud Kit
Screaming Eagle Head Gasket Kit
Oil Temperature Gauge Kit
Stock VROD front Brembo caliper and pads
Vivid Black Front Rotor
Stock Black Highlighted Cylinders (cosmetic only)
Stock Black Inner and Outer Rocker Box Covers (cosmetic only)
Screaming Eagle Black on Silver Timer and A/C Covers/Inserts
Stock HDI ‘Cush’ Drive (IDS) real pulley (Not installed yet, will install at first tire change along with black floating rear rotor)
Aftermarket Parts List:
Thunderheader (Black)
NRHS Hurricane K&\\;N Offset Performance A/C
Zipper’s Performance Adjustable Pushrods
Zipper’s Performance Adjustable Pushrod Tube Covers
Crossroads Performance Black Fork Brace
Crossroads Performance Clip-on handlebars
Doherty Machine Powervents
Dakota Digital 2 1/16†Speedo/ Tach combo
Black Pro 1 Pod Gauge mount for speedo tach
Russell Black SS front Brake Line
Progressive Rear Shocks
Chopperstyle 2†Tank Lift Kit
RaceTech Front Suspension Lowering Springs and Gold Valve Emulator Kit
[IMG]local://upfiles/26973/C427D81A86804032BF70FBFDF0A8EA41.jpg[/IMG]
Thanks
