test
Old Mar 30, 2008 | 11:34 AM
WS6 Formula's Avatar
WS6 Formula
Default test
Before and After Photos here:
http://*******.com/yl8hjuz
2006 Harley Davidson Dyna Low Rider
Dragonfly Green Pearl & Vivid Black
(Custom paint 1 of 233 only available Jan - Mar 2006)
(Before photos have reflectors and belt guards removed)
**Front End**
*H.D. 2006 Wide Glide 21" front wheel P/N 43563-06
*H.D. 2006 Wide Glide triple clamp upper P/N 46700-06
*H.D. 2006 Wide Glide triple clamp lower P/N 46386-06
*H.D. 2006 Wide Glide axle P/N 40923-06
*H.D. Chrome Tapered Front Wheel Spacer Kit P/N 41410-06
*H.D. Chrome Lower Fork Sliders P/N 46589-06A
*H.D. Billet Fork Slider Dust Covers P/N 46889-06
*Race Tech Gold Valve Cartridge Emulators P/N FEGV S4901
*Kuryakyn Front Axle Nut Covers P/N 1213
*H.D. Tinted turn signal lenses P/N 69304-02
*Painted turn signal reflector and internal housing flat black
*H.D. 2008 Screamin Eagle Dyna front turn signal mounts P/N 68266-03
*H.D. Classic Chrome Brake Caliper Insert P/N 44477-99
*DNA 11.8" Mesh Rotor
*Lyndell Gold+ Brake Pads P/N 7195
*H.D. 2006 Deuce headlight P/N 69715-05
*H.D. 2006 Sportster Custom, headlight mount P/N 67919-96
*Sylvania Silverstar H4 bulb
*Added a bushing between the lower headlight tabs (So tabs will not bend over)
**Hand Controls**
*H.D. Aileron Hand Grips P/N 56425-02
*H.D. Slotted Hand Control Lever Kit P/N 45459-07
*H.D. Chrome Switch Cap Kit P/N 71804-03
*Added a relay connected to high beam lead to trigger garage door opener
*Routed control wiring inside handle bars
*Routed front frame and console wire harnesses to left side of the bike
*Redressed all harnesses, cables, and hoses
*Removed reflectors, all factory decals, VIN, and emissions labels, and vapor canister
**Tank**
*H.D. 2008 Screamin Eagle Dyna Spun Aluminum Face 4" Speedometer - MPH P/N 67516-04B
*H.D. 2008 Screamin Eagle Dyna Spun Aluminum Face 4" Tachometer- RPM P/N 67522-04A
*H.D. Smooth LED Fuel Gauge P/N 75237-03A
*Tank lift 1.60"
**Engine**
*Arlen Ness Big Sucker I air filter kit P/N AN18-505
*Cut off the original air filter outer cover
*D&D Fat Cat 2 into 1 exhaust with quiet baffle P/N 496-32B
*H.D. Screamin’ Eagle Performance Exhaust Gasket Kit P/N 17048-98
*H.D. Screamin Eagle Race Tuner P/N 32107-01E
(base map # 141NX002 is for 8* injectors but using 25* injectors, +AFR, +VE, +Timing, - Cranking Fuel, - Idle, +Accel Enrichment, - Decel Enleanment)
*H.D. Screamin Eagle Yellow 10mm spark plug wires P/N 31987-85B
*Home made spark plug wire supports
*H.D. 10 Row Oil Cooler P/N 26110-05
*Billet finned timing cover (from eBay seller gregg5869)
*Relocated horn using rear engine mount bolt
*Installed banana jack on bottom of coil cover for battery tender
*H.D. Script Battery Cover Band P/N 66443-06
**Foot Controls**
*H.D. 2005 Forward control kit P/N 49080-03
*H.D. 2006 Polished Stainless Steel Gear Shift Linkage P/N 33815-06
*Removed the original shift lever without removing the primary
*H.D. 2007 Screamin Eagle Springer foot pegs P/N 52317-07
*H.D. 2007 Screamin Eagle Springer brake pedal P/N 42574-07
*H.D. 2007 Screamin Eagle Springer shifter peg P/N 49268-07
*H.D. 2007 Screamin Eagle Dyna Polished Stainless Steel Footpeg Mounting Pins (2 sets) P/N 42679-01
*Grinded down rear foot peg stops so pegs will tilt in more when in the up position
**Rear End**
*Custom Chrome lay down pyramid license plate mount P/N 14199
*Trimmed license plate to fit inside mount
*Kuryakyn Deluxe Smoked Tail Light P/N 4974
*Painted LED light face plate and inside of lens sides flat black
*H.D. Street Bob Seat P/N 51475-09A
*Green Pearl Seat Retaining ****
http://*******.com/23xxscm
*Modified Lower Belt Guard
*H.D. Front Belt Guard Bracket P/N 49216-06
*DNA 11.5" Polished Stainless Mesh Rotor
*DNA Chrome Mesh Pulley
*Vulcan Works 7/8" Pulley Spacer
*H.D. Chrome Tapered Rear Wheel Spacer Kit P/N 41411-06
*H.D. Script Rear Axle Cover Kit P/N 44346-06
*H.D. 2007 Street Glide Air Shocks P/N 54631-02B
**Tires**
*Dunlop Screamin Eagle Rear GT502 180/60B17 P/N 43197-04A
*Rear Fender Inner side plate brackets x 2 each, P/N 59514-06
*Dunlop 17" Tube P/N 40502-06
*Dunlop 17" Rim Strip P/N 43101-06
*Avon Venom 90/90B-21 FRONT (AV318)
*Dunlop 21" inner tube P/N 43140-80
*Dunlop 21" rim strip P/N 43939-89
*Dyna Balancing Beads
Part Numbers:
http://partsfinder.onlinemicrofiche....m_oem/hdmc.asp
Find your year, model, part, then put a 1 in the qty box of the item or items that you want the part number of, then click on "add items to parts list", then click on "send to cart" to get the part number.
Old Jun 2, 2010 | 10:11 PM
diablodrew's Avatar
diablodrew
Stage II
Hi.
Where did you get the chrome speedo housing and tank bib?
Drew
Old Jun 3, 2010 | 10:38 AM
ANIMAL03's Avatar
ANIMAL03
mmmmmmmmmm
