**INSTRUCTION SHEETs**
Old Sep 6, 2010 | 03:45 PM
  #31
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Default 2013-03-20 back up
Greetings to all of you!
As a member of this forum I would like to share some information on H-D instruction sheets with you.
Below you will find a database I was able to set up with the help of mud
** posting #1 shows the parts in numerical order < 58000-XX**
** posting #4 shows the parts in numerical order > 58000-XX**
** posting #2 shows the p/n's in alphabetical order A - H**
** posting #2 shows the p/n's in alphabetical order F - Z**
When you click the bold link (p/n) you will get access to the pdf file.
The database is far from being complete; just give me some time to do more research and add the info to the database.
Any addition from your side is more than welcome, just let me know in this thread.
Kind regards,
FXD2003Rider
numerical.....
16550-04 ...cylinder kit big bore SE mud 9-17-09
revision 2007-09-12
17378-98 ...Screamin' EagleŽ Roller Rocker Arms (fits '84-'99 EvolutionŽ 1340-equipped models, '86-later XL and XR models and '99-later Twin Cam-equipped models. Modification is required on Twin Cam rocker™ covers.) (added 10-31-2009) contribution of: wireguided
17675-01B ...Screamin' EagleŽ Forged Rocker Supports for Twin Cam Models (fits '99-later Twin Cam equipped models) (added 10-31-2009) contribution of: wireguided
17997-99A ...pushrods adjustable mud 9-14-09
18096-00A ...pushrod covers mud 9-14-09
18404-08 ...high performance quick-install adjustable pushrods (added 10-30-2009) contribution of: wireguided
25282-07...cam support plate mud 9-13-09
25284-08 ...hybrid cam plate and high flow oil pump kit (added 10-30-2009)
26081-05 ...Dyna Oil Cooler Kit (added 04-22-2011)
26151-07 ...Premium Oil Cooler Kit for DynaŽ Models (Fits '06-later DynaŽ models (except FXDSE/2, FXDFSE and California models). Does not fit with Front Spoiler Kits or Definitive5™ Filtration System Kits. Fits with all H-DŽ Engine Guards.) (added 11-08-2009)
27505-09 ...Screamin' Eagle 110 cubic inch stage I kit (fits '09 FXDF models) (added 10-30-2009)
29098-09 ...SE heavy breather performance air cleaner kit (added 09-19-2009)
29243-97 and 29244-97 Chrome air cleaner trim insert (used on Evo engine 8 inch A/C cover)
29299-08 ...SE heavy breather performance air cleaner kit (added 09-19-2009)
31705-04 ...dyna chrome coil cover kit (fits carburated versions) (added 10-26-2009) contribution of: 2007fxdc
31709-04 ...dyna chrome coil cover kit (fits EFI versions) (added 10-26-2009) contribution of: 2007fxdc
37970-03A ...clutch SE race mud 9-14-09
40063-05A ...automatic primary chain tensioner (added 09-15-2009)
40274-08 ...big twin compensator mud 9-13-09
43768-06 ...wide tire kit mud 9-17-09
43911-95 ...head bolt covers
44090-00 ...dual disc brake kit (will fit on '88-later XL, FXR and FXD models) (added Jan. 27-2010)
45023-02 ...triple tree
45030-03C ...black front master cylinder cover (Fits '96-'05 Dyna models) (added 01-13-2011)
45075-08 ...chrome hand control lever kit Fits '08-later DynaŽ and SoftailŽ models (added Jan. 01-2010)
45075-07 ...chrome hand control lever kit Fits '96-'03 XL models and '96-'07 DynaŽ, SoftailŽ and Touring models. (Does not fit Police models, VRSC™ models, or models equipped with hydraulic clutch.)(added Jan. 01-2010)
45078-96D ...chrome front master cylinder cover (Fits '96-'05 Dyna models) (added 01-13-2011)
45740-07 ...steering head washer kit (all 2006-2007 Dyna and 2008 and earleir FXDWG models) (added 11-06-2009)
46193-99 ...fork brace 39-41mm mud 9-14-09
46423-05A ...black front master cylinder cover kit (2006 - up Dyna models) (added 01-13-2011)
46424-05A ...chrome front master cylinder cover kit (2006 - up Dyna models) (added 01-13-2011)
46586-06 ...dyna chrome fork slider kit '06 and later (not for FXDWG, FXDF, FXDFSE & FXDSE/2) (added 10-17-2009)
46589-06 ...dyna fxdwg chrome fork slider kit (added 10-17-2009)
46595-06 ...fork brace 49mm mud 9-14-09
46646-05 ...brake rotor hardware kit (front) mud 9-18-09
48439-00B ...dyna chrome swingarm ('00 - '05 models) added 10-30-2009
48458-06 ...dyna chrome swingarm ('06 - '09 models) (added 10-30-2009) contribution of: wireguided
49021-09 ...dyna fwd control kit gloss black '06-later models (added 09-20-2009)
49080-03A ...dyna fwd control kit chrome '03-'05 models (added 09-20-2009)
49080-06A ...dyna fwd control kit chrome '06-later models (added 09-20-2009)
49279-06...dyna passenger footboard support kit (added 09-16-2009)
50210-06 ...passenger footpeg mounting kit (added 06-04-2010)
50357-04 ...swept-wing grooved passenger footboard kit (added 09-16-2009)
50451-09 ...mini footboard kit (added 10-21-2009)
50500247 Dyna Rider Foorboard Kit (for ’06-later FXD, FXDB, FXDC and FXDL models) (added 08/29/20125)
50601-01 ...Dyna Floorboard kit (added 09-14-2009) kit is obsolete; individual p/n's still available!
27-0920 ... Substitute by V-Twin Mfg(added 02-12-2010)
50886-02 ...Dyna Passenger Footboard Kit (fits 2002-2005 Dyna Models)
(added 12-31-2011)
53527-95A ...dyna docking hardware (added 09-25-2009)
53961-06...dyna docking hardware kit (added 09-19-2009) contribution of ackman1968
53964-06A...FXWG docking hardware kit (added 09-19-2009) contribution of sanlyn
53968-06 ...directional relocation kit (added 09-19-2009) contribution of ackman1968
55975-08A...street slammer handlebar kit (added 17-09-2009)
55977-09 ...fatbob handlebar kit mud 9-13-09
56165-03 ...handlebar polyurethane riser bushing kit (added 09-27-2009)
56290-05 ...deluxe pullback riser and clamp kit (added 10-11-2009)
56679-02 ...100th Anniversary handlebar grips (added 11-19-2009)
56916-07 ...handlebar riser kit fatbob mud 9-17-09
57340-08 ...detachable windshield and quick-clamp docking kit 49mm forks (added 10-03-2009)
57716-01 ...compact replacement windshield kit
For p/n's > 58000-XX go here
Old Jan 20, 2011 | 12:54 PM
  #32
FXD2003Rider
** posting #1 & 4 show the parts in numerical order**
** posting #2 & 5 show the parts in alphabetical order**
Kind regards,
FXD2003Rider
alphabetical.....
100th Anniversary handlebar grips... 56679-02 (added 11-19-2009)
Auxiliary Brake Light / Running Light / Turn Signal Conversion Kit - Bullet Lens Style... 69462-06A (added 09-26-2011)
brake rotor hardware kit (front)... 46646-05 mud 9-18-09
bullet headlamp kit 4 1/2"... 69851-06 (added 10-12-2009)
bullet headlamp kit 5 3/4"... 68593-06 (added 10-12-2009)
cam support plate... 25282-07 mud 9-13-09
chain tensioner (primary) automatic ... 40063-05A (added 09-15-2009)
Chrome air cleaner trim insert (used on Evo engine 8 inch A/C cover) ... 29243-97 and 29244-97
chrome auxiliary lamp kit (XL & FXD models)... 69284-05 (added 09-19-2009)
chrome auxiliary lamp kit (FXDWG models)... 69285-05 (added 09-19-2009)
chrome hand control lever kit... 45075-08 Fits '08-later DynaŽ and SoftailŽ models (added Jan. 01-2010)
chrome hand control lever kit... 45075-07 Fits '96-'03 XL models and '96-'07 DynaŽ, SoftailŽ and Touring models. (Does not fit Police models, VRSC™ models, or models equipped with hydraulic clutch.)(added Jan. 01-2010)
chrome switch cap kit ...71804-03 (added 04-10-2010)
chrome switch housing kit ...70222-96B (added 09-17-2009)
chrome front turn signal mounting bracket kit ...68266-03
clutch SE race... 37970-03A mud 9-14-09
COMBINATION SPEEDOMETER/TACHOMETER GAUGE KIT ...70900274 (added 09-21-2012)
COMBINATION SPEEDOMETER/TACHOMETER GAUGE KIT...74776-11 (added 04-06-2012)
compensator SE... 40274-089-13-09 mud
cylinder kit big bore SE... 16550-04 mud 9-17-09
revision 2007-09-12
deluxe pullback riser and clamp kit... 56290-05 (added 10-11-2009)
detachable windshield and quick-clamp docking kit 49mm forks... 57340-08 (added 10-03-2009)
detachable windshield kit 39mm forks... 58063-04 (added 10-03-2009)
directional relocation kit... 53968-06 (added 09-19-2009) contribution of: ackman1968
dual disc brake kit... 44090-00 (will fit on '88-later XL, FXR and FXD models) (added Jan. 27-2010)
dyna chrome coil cover kit (fits carburated versions)... 31705-04 (added 10-26-2009) contribution of: 2007fxdc
dyna chrome coil cover kit (fits EFI versions)... 31709-04(added 10-26-2009) contribution of: 2007fxdc
dyna chrome fork slider kit '06 and later (not for FXDWG, FXDF, FXDFSE & FXDSE/2)... 46586-06 (added 10-17-2009)
dyna fxdwg chrome fork slider kit '06 and later... 46589-06 (added 10-17-2009)
dyna chrome inner primary cover... 60794-06B (fits '06-later DynaŽ models (except FXDWG, FXDSE/2, FXDFSE and FXDF with Forward Foot Controls) (added 10-26-2009) contribution of: wireguided
dyna chrome inner primary cover... 60792-06B (fits '06-later FXDWG, FXDSE/2, FXDFSE/2 and '07-later SoftailŽ models (except FXCW, FXCWC, and '09 FXSTSSE3). Also fits '08-later FXDF models with Forward Foot Controls) (added 10-26-2009) contribution of: wireguided
dyna chrome inner primary cover... 60747-01 (fits '01-'05 FXDWG models) (added 10-26-2009) contribution of: wireguided
dyna chrome inner primary cover... 60751-01 (fits '01-'05 DynaŽ models except FXDWG) (added 10-26-2009) contribution of: wireguided
dyna chrome swingarm ('00 - '05 models)... 48439-00B (added 10-30-2009)
dyna chrome swingarm (06 -''09 models)... 48458-06 (added 10-30-2009) contribution of: wireguided
dyna detachable saddlebags... 90181-08 (added 09-22-2009)
dyna docking hardware... 53527-95A (added 09-25-2009)
dyna docking hardware kit... 53961-06 (added 09-19-2009) contribution of: ackman1968
dyna front spoiler chrome... 58043-04 (added 10-16-2009)
dyna front spoiler painted... 58042-04 (added 10-16-2009)
dyna fwd control kit chrome '03-'05 models... 49080-03A (added 09-20-2009)
dyna fwd control kit chrome '06-later models... 49080-06A (added 09-20-2009)
dyna fwd control kit gloss black '06-later models... 49021-09 (added 09-20-2009)
dyna glide front poiler kit... 58042-08 (added 10-17-2009)
dyna rear stop/tail/turn signal relocatioon kit... 68544-10 (added 10-05-2009) contribution of: billjoat
dyna rear turn signal relocation kit FXDB '09- later... 68227-09 (added 09-30-2009)
dyna rider footboard kit (for ’06-later FXD, FXDB, FXDC and FXDL models)...50500247 added 08/29/2012 contribution of greenstreetbob
dyna voltage regulator kit (2004 through 2005 FXDL/I & FXDWG/I) 74665-04 (added 10-26-2009) contribution of: 2007fxdc
dyna voltage regulator kit (2006 and later Dyna models) 74667-06 (added 10-26-2009) contribution of: 2007fxdc
For p/n's F - Z go here
Old Mar 6, 2011 | 09:22 AM
  #33
FXD2003Rider
For p/n's < 58000-XX go here
58006-87B ...windshield kit 39mm forks (added 10-05-2009)
58006-87C ...windshield kit 39mm forks (added 10-05-2009)
58042-04 ... dyna front spoiler, painted (added 10-16-2009)
58042-08... dyna glide front spoiler kit (added 10-17-2009)
58043-04 ... dyna front spoiler, chrome (added 10-16-2009)
58063-04 ...detachable windshield kit 39mm forks (added 10-03-2009)
58742-05 ...turn signal relocation kit (added 09-22-2009) (fits ’93-’05 FXDWG, ’86-later FXST, FXSTC, FXSTB, and ’00-’07 FXSTD models)
59802-05 ...quick release detachable windshield kit 41mm forks (added 10-03-2009)
60134-01 ...layback license plate mounting kit with directional bar (added 04-06-2010)
60215-06 ...layback license plate and turn signal relocation kit (added 09-30-2009)
60747-01 ...dyna chrome inner primary cover (fits '01-'05 FXDWG models) (added 10-26-2009)[/color] contribution of: wireguided
60751-01 ...dyna chrome inner primary cover (fits '01-'05 DynaŽ models except FXDWG) (added 10-26-2009)[/color] contribution of: wireguided
60794-06B ...dyna chrome inner primary cover (fits '06-later DynaŽ models (except FXDWG, FXDSE/2, FXDFSE and FXDF with Forward Foot Controls) (added 10-26-2009) contribution of: wireguided
60792-06B ...dyna chrome inner primary cover (fits '06-later FXDWG, FXDSE/2, FXDFSE/2 and '07-later SoftailŽ models (except FXCW, FXCWC, and '09 FXSTSSE3). Also fits '08-later FXDF models with Forward Foot Controls) (added 10-26-2009)[/color] contribution of: wireguided
62818-06C ...flush-mount led fuel gauge and gas cap kit (added 09-15-2009)
62974-09 ....lcd oil temperature/level dipstick (added 10-11-2009)
64245-97 ...leather tool box (right side tool box) (added 05-29-2010)
67224-95C ...FXD (Dyna Super Glide) tachometer kit (1995 --> 2003 models) added 12-19-2010
67224-04 ... tachometer kit (2004 --> later models) mud 09-13-2009
68000051 ...FLD Custom Auxiliary Lighting Kit (added 10-19-2012) contribution of: 1HD1C
68227-09 ...dyna rear turn signal relocation kit FXDB '09- later (added 09-30-2009)
68266-03 ...chrome front turn signal mounting bracket kit (added 04-10-2010)
68544-10 ...dyna rear stop/tail/turn signal relocatioon kit (added 10-05-2009) contribution of billjoat
68546-09 ...tribar led tail light kit (added 09-19-2009) contribution of sanlyn
68564-06 ...front turn signal relocation kit (added 09-22-2009) (fits ’06-’07 Dyna models (except FXDSE/2))
68593-06 ...5 3/4" bullet headlamp kit (added 10-12-2009)
68718-02 ...fxdwg turn signal relocation kit '02 - later (added 09-30-2009)
68732-02A ...rear turn signal relocation bar (fits domestic motorcycles) (added 09-30-2009)
68733-02A ...rear turn signal relocation bar (fits international (HDI) motorcycles) (added 09-30-2009)
68953-04 ....Mini tach gauge kit (added 01-17-2010) click for fitment info
68986-04 ....Mini tach gauge kit (added 01-17-2010)
69284-05 ...Chrome auxiliary lamp kit (XL & FXD models) (added 09-19-2009)
69285-05 ...Chrome auxiliary lamp kit (FXDWG models) (added 09-19-2009)
69433-08 ...turn signal relocation kit (added 09-22-2009) (fits ’08-later Dyna models)
69462-06A ...Auxiliary Brake Light / Running Light / Turn Signal Conversion Kit - Bullet Lens Style (added 09-26-2011)
69820-06 ...narrow mountingkit for rear turn signals (added 12-12-2009)
69851-06 ...4 1/2" bullet headlamp kit
70900274 ...COMBINATION SPEEDOMETER/TACHOMETER GAUGE KIT (added 09-21-2012)
70222-96B ...chrome switch housing kit (added 09-17-2009)
71804-03 ...chrome switch cap kit (added 04-10-2010)
74665-04 ...dyna voltage regulator kit (2004 through 2005 FXDL/I & FXDWG/I) (added 10-26-2009) contribution of: 2007fxdc
74667-06 ...dyna voltage regulator kit (2006 and later Dyna models) (added 10-26-2009) contribution of: 2007fxdc
74776-11...COMBINATION SPEEDOMETER/TACHOMETER GAUGE KIT (added 04-06-2012)
75051-08 ...LED fuel gauge kit, bar & shield (ad 09-18-2009)
75095-05A ...LED fuel gauge kit, skull (Fits '04-'08 FXDB, FXDL, FXD35, FXDWG and FXDF models, '07-'08 FXDC models) (added 11-08-2009)
75098-08 ...LED fuel gauge kit, skull (ad 09-18-2009)
75133-99 ...oil pressure gauge kit mud 9-13-09
75242-08 ...LED fuel gauge kit, smooth (ad 09-18-2009)
80061-00 ...muffler kit mud 9-18-09
90181-08 ...dyna detachable saddlebags (added 09-22-2009)
91558-01A ...remote-control garage-door opener kit (both transmitter & receiver) (added 09-17-2009)
91561-01 ...remote-control garage-door opener transmitter kit (added 09-17-2009)
91562-01 ...remote-control garage-door opener receiver kit (added 09-17-2009)
98965-99 ...lift adapters mud 9-13-09
Old Jan 13, 2012 | 12:14 PM
  #34
FXD2003Rider
For p/n's A-H go here
Floorboard Kit Dyna ... 50601-01 (added 09-14-2009) kit is obsolete; individual p/n's still available!
Substitute by V-Twin Mfg ... p/n 27-0920 (added 02-12-2010)
footboard support kit (passenger) dyna... 49279-06(added 09-16-2009)
footboard kit (passenger) swept-wing grooved ... 50357-04 (added 09-16-2009)
FLD Custom Auxiliary Lighting Kit ...68000051 (added 10-19-2012) contribution of: 1HD1C
flush-mount led fuel gauge and gas cap kit... 62818-06C (added 09-15-2009)
fork brace 39-41mm... 46193-99 mud 9-14-09
fork brace 49mm... 46595-069-14-09 mud
black front master cylinder cover (Fits '96-'05 Dyna models) ...45030-03C (added 01-13-2011)
front master cylinder cover kit (chrome) (Fits '96-'05 Dyna models) ...45078-96D ...(added 01-13-2011)
front master cylinder cover kit (black) (2006 - up Dyna models) ... 46423-05A (added 01-13-2011)
front master cylinder cover kit (chrome) (2006 - up Dyna models) ... 46424-05A (added 01-13-2011)
FXD (Dyna Super Glide) tachometer kit (1995 --> 2003 models)... 67224-95C ... added 12-19-2010
FXWG docking hardware kit... 53964-06A (added 09-19-2009) contribution of: sanlyn
fxdwg turn signal relocation kit '02 - later... 68718-02 (added 09-30-2009)
handlebar kit fatbob... 55977-09 9-13-09 mud
handlebar polyurethane riser bushing kit... 56165-03 (added 09-27-2009)
handlebar riser kit fatbob... 56916-07 mud 9-17-09
head bolt covers... 43911-95
high performance quick-install adjustable pushrods... 18404-08 (added 10-30-2009) contribution of: wireguided
hybrid cam plate and high flow oil pump kit... 25284-08 (added 10-30-20090
layback license plate mounting kit with directional bar... 60134-01 (added 04-06-2010)
layback license plate and turn signal relocation kit... 60215-06 (added 09-30-2009)
lcd oil temperature/level dipstick... 62974-09 (added 10-11-2009)
leather tool box (right side tool box)... 64245-97 (added 05-29-2010)
led fuel kit gauges, bar & shield ...75051-08 (added 09-16-2009)
led fuel gauge kit, skull (Fits '04-'08 FXDB, FXDL, FXD35, FXDWG and FXDF models, '07-'08 FXDC models) ...75095-05A ... (added 11-08-2009)
led fuel kit gauges, skull ...75098-08 (added 09-16-2009)
led fuel kit gauges, smooth ...75242-08 (added 09-16-2009)
lift adapters... 98965-99 9-13-09 mud
mini footboard kit... 50451-09 (added 10-21-2009)
mini tach gauge kit... 68953-04 (added 01-17-2009) click for fitment info [/COLOR]
mini tach gauge kit... 68986-04 (added 01-17-2009)
muffler kit... 80061-00 mud 9-18-09
narrow mounting kit for rearurn signals... 69820-06 (added 12-12-2009)
Oil Cooler Kit for Dyna...26081-05 (added 04-22-2011)
oil pressure gauge kit... 75133-99 9-13-09 mud
passenger footpeg mounting kit... 50210-06 (added 06-04-2010)
Premium Oil Cooler Kit for DynaŽ Models (Fits '06-later DynaŽ models (except FXDSE/2, FXDFSE and California models). Does not fit with Front Spoiler Kits or Definitive5™ Filtration System Kits. Fits with all H-DŽ Engine Guards.)... 26151-07 (added 11-08-2009)
pushrods adjustable... 17997-99A mud 9-14-09
pushrod covers... 18096-00A mud 9-14-09
quick release detachable windshield kit 41mm forks... 59802-05 (added 10-03-2009)
rear turn signal relocation bar (fits domestic motorcycles)... 68732-02A (added 09-30-2009)
rear turn signal relocation bar (fits international (HDI) motorcycles)... 68733-02A (added 09-30-2009)
remote-control garage-door opener kit (both transmitter & receiver)... 91558-01A (added 09-17-2009)
remote-control garage-door opener transmitter kit... 91561-01 (added 09-17-2009)
remote-control garage-door opener receiver kit... 91562-01 (added 09-17-2009)
SE heavy breather performance air cleaner kit... 29098-09 (added 09-19-2009)
SE heavy breather performance air cleaner kit... 29299-08 (added 09-19-2009)
SE 110 cubic inch stage I kit for EFI models (fits '09 FXDF models)... 27505-09 (added 10-30-20090
Screamin' EagleŽ Forged Rocker Supports for Twin Cam Models (fits '99-later Twin Cam equipped models)... 17675-01B (added 10-31-2009) contribution of: wireguided
Screamin' EagleŽ Roller Rocker Arms (fits '84-'99 EvolutionŽ 1340-equipped models, '86-later XL and XR models and '99-later Twin Cam-equipped models. Modification is required on Twin Cam rocker™ covers.) ... 17378-98 (added 10-31-2009) contribution of: wireguided
steering head washer kit (all 2006-2007 Dyna and 2008 and earlier FXDWG models)... 45740-07 (added 11-06-2009)
street slammer handlebar kit ...55975-08A (added 17-09-2009)
tachometer kit... 67224-04 mud 9-13-09
tribar led tail light kit... 68546-09 (added 09-19-2009) contribution of sanlyn
triple tree... 45023-02
turn signal relocation kit (fits ’93-’05 FXDWG, ’86-later FXST, FXSTC, FXSTB, and ’00-’07 FXSTD models)... 58742-05 (added 09-22-2009)
turn signal relocation kit (fits ’06-’07 Dyna models (except FXDSE/2))... 68564-06 (added 09-22-2009)
turn signal relocation kit (fits ’08-later Dyna models)... 69433-08 (added 09-22-2009)
wide tire kit... 43768-06 mud 9-17-09
windshield kit 39mm forks... 58006-87B (added 10-05-2009)
windshield kit 39mm forks... 58006-87C (added 10-05-2009)
windshield kit compact replacement... 57716-01
Miscellaneous:
2009 Dyna Models Power Commander Installation Instructions...added April 14-2011
Old Nov 11, 2012 | 12:04 PM
  #35
FXD2003Rider
Originally Posted by FXD2003Rider
Great pix, mud! Thanks for sharing.
@ Bill & Cole:
Anxious to read the story behind the t-shirt exchange in this image:
Roger that, mud. Zooming in on the image I see the HDF logo on the bag. Anxious to learn (for the record) when this bag was made, used for the first time and by whom.....
Old Aug 15, 2017 | 01:52 AM
  #36
MidnitEvil's Avatar
MidnitEvil
Link for instruction sheet for 50886-02 above doesn't work.
Here's a link to a page with the instructions from Google's cache
https://webcache.googleusercontent.c...&ct=clnk&gl=us
Old Aug 15, 2017 | 09:08 AM
  #37
FXD2003Rider
This is a test area.
The links provided by me in the database do no longer work.
I did some searching and found out MoCo has opened a SERVICE INFORMATION PORTAL (click link to access the portal)
Once you have opened the Service Portal clik the "Search" button (r/h top corner).
Now the GLOBAL SEARCH page opens.
Follow the instructions showed and enter either the p/n without the suffix letter or the Instruction Sheet's Jcode without the prefix dash into the query box.
Confirm the search query and a new screen with relevant info opens.
Click "Search" in the right hand top corner of the screen and a search box comes up:
Now enter the p/n or J# , activate the search engine and a results list comes up
Now left click INSTRUCTION SHEETS (1) ...
...and the IS comes up...
mud
Testing Area
Dec 31, 2010 05:41 PM
