Instruction sheet database thread test
Old Sep 13, 2009 | 12:42 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Default Instruction sheet database thread test
Greetings to all of you!
As a member of this forum I would like to share some information on H-D instruction sheets with you.
Below you will find a database I was able to set up with the help of mud
The first part shows the p/n's in numerical order, the second part shows the parts in alphabetical order.
When you click the bold link (p/n) you will get access to the pdf file.
The database is far from being complete; just give me some time to do more research and add the info to the database.
Any addition from your side is more than welcome, just let me know in this thread.
Kind regards,
FXD2003Rider
numerical.....
25282-07 ...cam support plate
40274-08 ...big twin compensator
43911-95 ...head bolt covers
45023-02 ...triple tree
55977-09 ...fatbob handlebar kit
57716-01 ...compact replacement windshield kit
67224-04 ...tachometer kit
74556-09 ...speedo/tacho combination- nostalgic face (added 09-13-2009)
75133-99 ...oil pressure gauge kit
98965-99 ...lift adapters
alphabetical.....
cam support plate... 25282-07
compensator SE... 40274-08
handlebar kit fatbob... 55977-09
head bolt covers... 43911-95
lift adapters... 98965-99
oil pressure gauge kit... 75133-99
speedo/tacho combination- nostalgic face... 74556-09 (added 09-13-2009)
tachometer kit... 67224-04
triple tree... 45023-02
windshield kit compact replacement... 57716-01
Last edited by FXD2003Rider; Sep 13, 2009 at 03:46 PM. Reason: added new info 09-13-2009
Old Sep 16, 2009 | 03:38 PM
FXD2003Rider
Default link
box.net
Old Jan 2, 2010 | 05:44 AM
FXD2003Rider
Arrow ***Write-up on how to add images to a post***
Before you even TRY to post a picture on HDF (see image below):
1. go to your User CP (upper left side of page on blue toolbar) and click on it.
2. Scroll down to "Edit Options" click on it.
3. Now scroll all the way down to the bottom and
4. change from "Basic Editor" to "Enhanced".
5. Confirm settings by clicking "Save Changes" .
If you have not done this then HDF will not allow you to post pictures. (Terry1955; "Administrator & Troll Slayer", 02-20-2010)
Here's how to add (large size) images to a post:
I use a free account at photobucket.com to copy/paste pics into a post.
First you have to upload your pictures from your computer to your photobucket account.
1. Go to your Photobucket account
2. Left click the green button
3. Left click the green button
4. Find the folder on your computer where your image is stored
5. Select the image(s) and left click "open"
6. Add a title, description and tag (as desired) to the image
7. Left click the blue button
When posting at HDForums.com, here's how to add an image:
1. Find the image in your Photobucket account
2. Left click the IMG code text bux under the image
3. Right click this IMG code and select "copy"
4.Go to your post at HDForums.com and paste the IMG code into the text
If wanted, you can preview your post and click "Submit reply".
If you need some more help, just shoot me a PM
Old Nov 18, 2010 | 02:57 PM
FXD2003Rider
Default How to edit your Avatar
Here's how to add an images to your Avatar:
Before you start select an image you want to use and be sure it's size
does not exceed 150 by 150 pixels or 1,91 MB (whichever is smaller).
I use MS Paint to check these numbers and to re-size the image of needed.
Click "User CP" and "Edit Avatar" (see image below):
Click "Use Custom Avatar" checkbox, click "Browse" to find the image
on your computer, select the image and click "Open" (see image below):
Now click "Save Changes" and check the result in your User CP (see image below):
Old Dec 16, 2010 | 02:25 PM
FXD2003Rider
Default Image size test
100X75
160X120
320X240
640X480
800X600
Old Dec 20, 2010 | 04:22 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Nicely done.
Old Dec 20, 2010 | 04:26 PM
FXD2003Rider
Originally Posted by Citoriplus
Nicely done.
Thanks, Ken..
This is my private play-ground as you will have noticed.
René
Old Dec 20, 2010 | 04:30 PM
Your welcome, and I'm Frank.
Old Dec 21, 2010 | 12:20 AM
FXD2003Rider
I'm so sorry, Frank
Old Sep 29, 2011 | 01:19 PM
FXD2003Rider
test.....
