The Dark Side For those members running "Car Tires" on their scoots. This is for their discussion only and not a place for "non dark siders" to mouth off about their negative opinions of this idea!
98 electra glide
Old Apr 1, 2019 | 04:37 PM
John Dungan's Avatar
John Dungan
Stage III
Default 98 electra glide
Looking for tire suggestions for my 98 electra glide, it currently has a Michelin 130/90/b16 what would be good dark side to go to, having issues finding a replacement size.
Old Apr 1, 2019 | 09:12 PM
Bonnie Storm's Avatar
Bonnie Storm
I have done some checking and all I could come up with was the Austone 175r16 but those are no longer manufactured. It might be possible for you to run a 195/60r16 though the clearance might be a issue. The majority of pre 2009 Harley's if not all, don't really have a lot of room.
Old Apr 1, 2019 | 09:16 PM
John Dungan
Stage III
Thanks Bonnie, I was afraid that might be the situation.
Old Apr 1, 2019 | 09:31 PM
Bonnie Storm
Not a problem. I was trying to match your stock tires diameter so you wouldn't need to correct the speedometer. Otherwise you could potentially go a tad smaller with a 175/60r16. For perspective, your original tire is 25.2 inches in diameter where the 175/60r16 is 24.3 inches, almost an inch difference. You would be traveling several mph less than what your speedometer reads.
It's a thought, maybe even an option!
Old Apr 9, 2019 | 06:41 AM
Eggman1's Avatar
Eggman1
If you aren't skeered to do it, one can always fit a 205/55R16 on an 07 or earlier.
A change of the rear swing arm and fender, rear frame, and axle spacers would be a start.
Old Apr 9, 2019 | 11:57 AM
smitty901's Avatar
smitty901
use this to compare tires and get measurements it works
https://www.tacomaworld.com/tirecalc...5r16-195-60r16
Old Jun 20, 2019 | 03:35 PM
terryrh's Avatar
terryrh
I checked this out because a friend asked me about this sizing not too long ago. I am really surprised that I don't see more with the older bikes or the Softails throwing the size up here. I wish I could remember what size/brand I used on my Heritage.
matt_m_72
May 14, 2015 08:12 AM
KJOGlide
Wheels/Tires
Jun 21, 2013 10:27 AM
Firedawg473
Sep 21, 2011 08:55 AM
sietse
Wheels/Tires
Aug 17, 2011 02:32 PM
nardo
Nov 22, 2007 11:42 AM
