HARLEY: Super tuner smart tune problem
I am using a 09 fatboy with SE Breather and High-Output Slip-Ons.
I want to tune my bike with Super Tuner.
I used 176AE106 as a base map.
Then I started recording for four sessions.
After that I wanted to use the log-files with smart tune to become a more fitting VE table.
I loaded the log-files to smart tune but after hitting "generate" nothing happens to the tables.
They stay filled with zeros.
I can´t believe that there is nothing to do with the base map.
I was running on highway while recording trying to use every gear from 2500 revs up to the limit.
I was doing several full throttle runs and I was just riding around for at least two hours.
In that time I did 4 recordings.
If I load the log-files to mytune it shows differences in VE tables but I just can see that some fields are changing to blue and some to red but can not use mytune because it is only trial-version.
But this tells me that there are changes.
Why does Super Tuner not see them?
I added some screenshots from mytune.
It shows the changes and the hit-counts.
What also makes me wonder is that on hit-counts there seems to be nearly no hits between 30% and 60% TPS.
Can anyone help me out here?
I have emailed the files to you.
It is within a zip file because data would be to much to send from my mailprog.
@lonewolf:
I have checked the box and tried again.
Still nothing happens.
It seems I am doing something wrong but what?
