The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
Other Devices: issues with my MAP
Old Jul 26, 2016 | 10:49 AM
FLTRI17's Avatar
FLTRI17
"I just ordered a Power Commander 5 in hopes that will help me out down the road. but for now I need to get it running with this digital fuel pack, enough so I can ride it."
Why not just make the decision to get a flash tuner (recalibrate the ECM in lieu of another bandaide system) so you retain the O2 sensors to keep your bike in tune with all the different fuel formulae we deal with across the states, cities, and counties?
Don't cut off a good part of what the ECM can do simply because it appears to be a plug and play system.
There should be a plethora of 551 calibrations to pick from so you should be real close to begin with and with a proper tuner you can dial in the rest without much more knowledge that in takes to make changes to a power commander.
Cheap fixes and add-on boxes rarely make for good long term decisions and run quality as compared to a properly tuned bike without the latency generated from a power commander or any add-on device.
Just my opinion from years of tuning these bikes,
Bob
Old Jul 26, 2016 | 11:19 AM
UltraNutZ's Avatar
UltraNutZ
yeah that PCV will be a world of difference from this thing.
I talked to a buddy of mine who used to work for V&H, here's what he suggested.
2/10, 4/10, 45/50, 46/50, 47/50
Give that a whirl and let's see what happens
Old Jul 26, 2016 | 12:36 PM
Diverrick's Avatar
Diverrick
Is that on top of the changes I already did this morning? or Should I set it all back to original then make the changes?
Old Jul 26, 2016 | 12:48 PM
UltraNutZ's Avatar
UltraNutZ
set back to original and then make these settings.
Old Jul 26, 2016 | 12:49 PM
Diverrick's Avatar
Diverrick
Thanks Ultra. While I was waiting for a response from you I went out and simply added the adjustments you told me to do, to the ones that V&H told me to do. with 45, 46, and 47 at 50 it improved a lot, but was still running a bit rough, and small poping sounds, so I figured why not try 45 on all three places. That really smoothed things out. Still sound like it is missing a bit, but the poping is all but gone. So we are making progress.
Old Jul 26, 2016 | 12:58 PM
Diverrick's Avatar
Diverrick
I set everything back to original and then entered your number only. Seems to run worse, but not as bad as it was with the full original numbers. Now it sounds like it is missing throughout the range. RPM si moving about 200 RPM, and you can here it missing.. Pop is fully gone now.
Old Jul 26, 2016 | 01:00 PM
UltraNutZ's Avatar
UltraNutZ
when I say original, I mean the original values of the FP-4487 calibration
Old Jul 26, 2016 | 01:10 PM
Diverrick's Avatar
Diverrick
yes. Put all the numbers back to FP-4487. then added yours to the cells called for.
Old Jul 26, 2016 | 01:12 PM
UltraNutZ's Avatar
UltraNutZ
go ride it see how she feels.
the thing I hate about this device is the disconnecting of the o2 sensors. IMO these are crucial in allowing your HD ECM to determine where your device is off and adjust itself.
Old Jul 26, 2016 | 05:03 PM
Diverrick's Avatar
Diverrick
yea I was wondering this myself, how would it have any idea what the A/F ratio is doing, without some sort of probe to sample.? Can the PC-5 use wide band probes, or the originals? I have all 4 bungs for both wide band, and narrow band sensors I'll need to wait until it cools off some before riding it.. It is 104 right now..
