The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
TTS: AFR table
Old Sep 17, 2019 | 10:43 PM
09fxdfse's Avatar
09fxdfse
Default AFR table
Why is it that the main AFR table only goes to 6000 rpm while the other tables go to 7000 rpm ?
Old Sep 18, 2019 | 10:17 AM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Because there is really no need to change the fuel mixture above that RPM on a HD Vtwin engine.
Old Sep 18, 2019 | 06:27 PM
09fxdfse's Avatar
09fxdfse
so the ecm uses the last value when the engine is outside the range of the table ?
does this apply to other tables ?
thanks
Old Sep 20, 2019 | 03:58 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
thanks
Yes, if the table ends at 6000 RPM and you run it to 8000 RPM it still uses the value at 6000.
HD_Doobie
2014-2024 Touring Models
152
Jun 13, 2016 10:35 AM
cgptv
Oct 7, 2015 12:10 PM
N-gin
Jul 25, 2010 08:31 AM
rbabos
Jul 1, 2008 05:06 PM
ramn
Mar 22, 2007 08:54 PM
