DYNOJET: Question about new map
Greetings. I just changed cams and have a canned map made specifically for my cam and exhaust. The bike seems to run fine but idles a bit rough. I was advised by Fuel Moto to run the bike for awhile because it's takes some time for their fuel trims to dial in. I'm guessing that means I should hold off on any auto tunes for awhile. Sound right? Something I didn't know. Thanks
I had a similar issue with idle up to 2000 rpm.. Auto tuning did not help (only made it worse) so I went into the VE tables and made my own adjustments and I like the the response now.. It's in this thread if you interested..
https://www.hdforums.com/forum/the-d...ctor-size.html
Originally Posted by hrdtail78
I would suggest auto tunes right away. You can let it trim in, but where are those trims with in the limits of how much it can trim? What auto tune basically does is apply these trims to the VE to where they are suppose to be for the airflow and center your trim tables.
Life is great when the bike is running good.
stagolee
Apr 23, 2008 06:58 PM
